Viewing 15 posts - 1,246 through 1,260 (of 6,225 total)
  • in reply to: Displaying a group of daily data points #13947
    would it be possible to modify the table view and make a version that displays daily data?
    It may be possible in the future, but there is no such task in our road map 2024.
    in reply to: Displaying a group of daily data points #13940
    Table views are designed for displaying hourly data.
    I suppose, to display daily data you should try Elastic Report plugin. It’s documentation is here.
    The idea is the following:
    1. Configure an elastic report as you need.
    2. A report can be displayed as a web page accessed by a certain URL. URL arguments can be modified to display last 7 or 10 days relatively.
    3. Add an URL in the Views table to add a node in the view explorer tree.
    Ask for details of each step if needed.
    in reply to: New ScadaAdmin Project in Version 5 #13938
    This is very old version of ScadaAdmin that uses MSSQL compact database. Just skip it.
    in reply to: lack of Basic Control after compiling ScadaScheme #13937
    To run and debug the project you should manually copy the compiled files to the same locations which is used when you install Rapid SCADA from the distributive. This is because the compilation results of several projects is needed to run Rapid SCADA applications.
    in reply to: lack of WinControl #13936
    WinControl 2.2.0 is created for the future use. This version is not compatible with current and previous versions of ScadaAdmin.
    in reply to: config file hot reload #13935
    In v6 channel limits can be bound to other channels, so they can be changed by an operator.
    User editing in runtime has not been implemented yet. Still in plan. The most similar option is using Active Directory to manage users. The is a module to auth user by Active Directory.
    in reply to: web station bug #13934
    What buttons should I click to reproduce the issue?
    in reply to: Update from 5.8.3 to V6 #13933
    When converting a project from v5 to v6 units are compared by their codes. So UnitID may change.
    > by any chance is it possible to use a V5 SCADA with Rapid Gate to connect to a V6 ?
    No, because the application communication protocol and the configuration database significantly changed.
    > if I upgrade from V5 (delete all) and install new V6 (latest, windows), the computer code and the license remains the same?
    The code will change. If you buy licenses before, we upgrade keys for free on the same computer.
    > on V6 is it possible to change the layout of the landing page (main page) as it was on V5?
    In general, yes. Screenshot is needed for more details.
    Thank you for the update 🙂
    in reply to: ScadaAdmin Compile Issues #13918
    You should check and fix the project dependencies.
    in reply to: lack of WinControl #13917
    WinControl source code is here.
    If you try to build v5, you need to download the dlls repository.
    in reply to: lack of Basic Control after compiling ScadaScheme #13916
    You should put *.dll files to proper locations. I recommend to install Scheme Editor from the distributive, and check the required files in the installation folder.
    in reply to: How to use ModArcPostgreSql? #13915
    OK. I hope we will create a module to calculate consumption in the future.
    in reply to: Create Array template elements #13914
    The Modbus driver does not create data tags of the array type. If a device has a list of similar registers, you could create a “request” (in terms of the driver) that includes the necessary number of elements to read. In this case, the driver creates a group of data tags.
    in reply to: How to use ModArcPostgreSql? #13903
    I see. It would be handy. For now, there is no ready to use solution.
    If there is a business need and you could sponsor that feature, I could create a prototype of the module that will become a part of Rapid SCADA.
