Please provide screenshots describe you issue. To be honest, I don’t understand the problem.
MikhailModeratorPerhaps when prompted in RapidScada need to specify the address of the register + 1
In addition, you can choose addressing (zero based or 1 based) in the template settings.
A developer of a driver may test it on Linux or not. You should read a description of a driver you need.
MikhailModeratorOPC is an additional level that can cause issues. Modbus is clear.
If it’s possible to use Modbus, I’d prefer Modbus rather than OPC. However, MatLab integration is not typical task.
You need to specify the IP of the Server into Communicator settings.
MikhailModeratorI can try to fix it using remote connection if you OK with the commercial service. For pricing, please send a request to this email.
You should provide a part of communication line log where we can see the raw data packages from the device. And provide screenshot of the Modbus template.
MikhailModeratorAdd a command to your Modbus template, restart Communicator and try the command using the UI of Communicator. When you sure it works, you can add output channel in Administrator.
This reply was modified 7 years, 11 months ago by
You create an interesting system.
What Modbus registers do you need to set by a command?
You could try to configure the command as you expect, and if it doesn’t work, post screenshot links of the settings to discuss them.
If you can’t fix it by yourself, be free to ask.
MikhailModeratorNo programmatic limits. You should check performance of your real system.
