This calculation is difficult to implement using built in formulas because they work with current values. I suggest Elastic Report plugin, please check the demo which performs what you need.
If you switch off Automatic Control Module, does the problem appear?
MikhailModeratorDo you use Automatic Control module?
MikhailModeratorInteresting and simple.
MikhailModeratorYour formula is incorrect for binary command. It have to return array of bytes. Instead of CmdVal you need CmdData variable. I can write you a correct formula for a fee. Creating formulas is out of free support.
MikhailModeratorTry the same configuration of Rapid SCADA on another computer to check if this issue constantly appears or depends on the particular PC.
MikhailModeratorTo use a link you need to update Rapid SCADA to the latest version.
I see.
Quick solution is using a link component on a scheme and specify an URL to a chart.
The best solution is updating the web application to support the appropriate option. This could be done on commercial base.
MikhailModeratorMost likely.
Please remind what is the version of SCADA-Server now? I strongly recommend 5.1.0.4
MikhailModeratorGo to gmail account settings. Open the “Forwarding and POP/IMAP” tab and try enabling POP.
Provide screenshots please.
MikhailModeratorYou can also update by replacing files, but it’s easy to make a mistake.
1. You should post here a part of Server log.
2. Please send me the new computer code by email. I will check the changes.Is there another way to back up and restore the license more quicly and safety?
The key becomes invalid because of some changes in the environment. I will check them when receive the new computer code.
Is there the way to update software to new version more convenience?
The recommended way is here as you noticed.
MikhailModerator -
