MikhailModeratorScheme Editor v5.2.3.1 is fresh. A Link component is installed by default.
Scheme Editor looks for the components in C:\SCADA\ScadaWeb folder. Do you have Webstation installed?
MikhailModeratorYou need to develop a driver that recognizes the file format you use.
I suggest, import from a database that works out-of-the-box.
The modem doesn’t respond. First of all, check serial port settings in Rapid SCADA.
Do you mean to import data from the file to Rapid SCADA and show these data?
MikhailModeratorWatch the video about the editor to view all components.
There should be more components. What version of Scheme Editor do you use?
Yes, this is a limit. Input channel values are stored in a “double”, which has 8 bytes.
There is a default component in Scheme Editor named Link. Put a link on your scheme and set the properties of the Navigation group.
If you need to open another Rapid SCADA view, set View ID. If you need to open external resource, set Url.
Yes, it’s possible now. Please start a new topic if you need more details, because this topic has another subject.
MikhailModeratorFixed in Language Pack 1.4
MikhailModerator1. I can fix it remotely for a fee.
2. There is also another way to port the existing project to the new version.
2.1. Install Rapid SCADA 5.7.1 and make sure everything works well.
2.2. Import the configuration database tables from the old configuration. I will provide more info how to import if needed.
You should open the Input Channels table and tick the checkboxes of the appropriate channels: Write Events, Event on Change.
MikhailModeratorStrange that you can’t connect.
Other way to try:
Click edit profile before reading the configuration, and change the user to ScadaWeb, also set correct password of ScadaWeb user.
MikhailModeratorThe “Default” instance is specified in the Agent configuration. I think, it’s OK.
I added user ScadaAdmin with password 12345 and application role.
Did you pass the configuration to the server using the old Administrator?
Agent looks for the user ScadaAdmin in C:\SCADA\BaseDAT\user.dat -
