Hyperlink between windows
Forum Home › Forums › Understanding the Software › Hyperlink between windows
Viewing 13 posts - 1 through 13 (of 13 total)
  • #5900
    danielfernandes
    I need more details for implement hyperlink between text or image for another window.
    In other topic, Mikhail speak that it was possible but I don’t know how doing.
    Can you explain?
    Regards.
    • This topic was modified 7 years, 1 month ago by Mikhail.
    #5902
    There is a default component in Scheme Editor named Link. Put a link on your scheme and set the properties of the Navigation group.
    If you need to open another Rapid SCADA view, set View ID. If you need to open external resource, set Url.
    #5903
    danielfernandes
    In the Scheme Editor, should I have one component with name link?
    In link below, I send image of my Scheme Editor window:
    https://drive.google.com/open?id=1sbwZu5B3Y4mBJkrdWpoXYW5xHM22sUjo
    Regards.
    #5908
    There should be more components. What version of Scheme Editor do you use?
    #5909
    Watch the video about the editor to view all components.
    #5912
    danielfernandes
    The version of Scheme Editor is 5.2.3.1. I doing download of the below link.
    https://rapidscada.org/download-all-files/
    Where I found the video about the editor?
    Do you know because I not have all components?
    #5922
    Scheme Editor v5.2.3.1 is fresh. A Link component is installed by default.
    Scheme Editor looks for the components in C:\SCADA\ScadaWeb folder. Do you have Webstation installed?
    Video Link.
    #5925
    danielfernandes
    I follow the steps of installation but I don’t remember of the Webstation.
    How I can verified if the webstation is installed? And, How I can install webstation?
    #5926
    danielfernandes
    I already remember of webstation, yes, and I installed the webstation.
    #5927
    Please check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log
    There are information about loading components.
    #5928
    danielfernandes
    The log file notified that exit error in loading the plugin assembly c:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll.
    I found in forum that the activation of PlgSchExtraComp resolve this problem but this plugin require key.
    I try require the trial key but I don’t know the compute code.
    #5929
    danielfernandes
    Thanks for all support.
    In really, My problem was in PlgSchBasicComp.dll because this file was blocked by windows.
    Although of the other questions in this forum, I understand the problem and I found the solution.
    Thanks and regards.
    #5930
    Basic Components do not require any key.
    And all components work in Scheme Editor despite they need a key or not.
    I’m glad that now components work.
