Culture 'es-LA' doesn´t takes effect
Forum Home › Forums › Installation Issues › Culture 'es-LA' doesn´t takes effect
  • #4403
    jmartins
    Hi all.
    Installed RapidSCADA v5.5.3 in different ways/computers/Windows OS´es, but never had success on changing the default english interface to ‘es-LA’.
    Unzipped the lang_pack_1.3 files at the proper places and set “es-LA” at the Culture field on the WebCondfig.aspx (v5.0.6.0) application, but after relogin or restart all remains in english as usual.
    Also tried to do the same at the Administrator->Settings->Language: on the drop-down control doesn´t appears the “Spanish (es-LA)” option, just “English (en-GB)” and “Russian (ru-RU).
    I´ll appreciate any guidance to solve this.
    Best regards.
    #4407
    You should read this.
    Also check ScadaWeb\log\ScadaWeb.log for additional information about the error.
    #4408
    Just type manually. It’s normal. After change here, restart IIS or restart the PC.
    #5893
    The answer is here.
