Using variables on SCADA-Scheme Editor
Forum Home › Forums › Understanding the Software › Using variables on SCADA-Scheme Editor
  • #173
    teleco
    I would like to know if it is possible to declare a variable (var1, e.g.) and associate it to “x” or “y” parameters, from “location field” of dinamic or static pictures or texts.
    My idea is to represent the movement, for example, of an object, with the variation of variables associated to “x” and “y”, making them dynamics in some way.
    #175
    I understand your idea. To be honest, I had the same thoughts. But it is not supported. The other approach is preferable. Most likely SCADA-Web would contain a system of visual components those implement dynamics.
    #1695
    jeeslo
    Hi! Mikhail
    I want to know the possibility in the scada-scheme on the part Behavior-editor> action allowed actions so far and send Draw Command diagram.
    Hyperlink is possible to add the option, this would serve to link to another more detailed scada or to an aid of an alarm on the web-site Wiring plan or table.
    regards
    #1696
    Hi Jesus,
    Hyperlinks are important, and they would be surely added to the Schemes. For now I can’t tell the exact date when it is ready.
    P.S. Save our Facebook page https://www.facebook.com/RapidSCADA/ to read latest news related to Rapid SCADA.
    #5898
    danielfernandes
    Hi Mikhail,
    I want to know the possibility of the implement hyperlink between text or image for another window.
    I found this question with data of 2016 and I think that is exactly I need.
    Is it solution already possible?
    Regards.
    #5899
    Yes, it’s possible now. Please start a new topic if you need more details, because this topic has another subject.
