MikhailModeratorGood 🙂
March 8, 2021 at 9:33 am in reply to: Why ModDBExport Module is not publishing realtime or current data? #8438
SQL requests defined in the module settings are executed when new data are passed from Communicator to Server app.
Please provide links to the screenshots of the module settings and copy logs here. I can check them.
MikhailModeratorThis screenshot shows that the device tags are not bound to input channels. To do that make sure that the input channels were created and the Signal field of that channels > 0 (e.g., 41, 42, 43 and 44 according to the screenshot).
The instruction linux_install.txt is inside the installation package.
MikhailModeratorI need read the value and change the value, but datatype is float and yesterday I cant modify the vale
Do you get an error? What text is in the communication line log? Please describe sending command issue in details.
MikhailModeratorHow many different input channels you need to open using this approach?
Do you need to add several links on the parent scheme, and each link is open the same child scheme having corresponding input channels?
MikhailModeratorPlease try the update of KpOpcUa.dll
Fixes:
– browse nodes
– Int16 and Boolean typesString commands is currently not supported. It’s possible to support them.
Let me know about the results.
I can connect to opc.tcp://83.42.220.118:4840
I will check and write here
Where is the data stored before it is displayed on the web server?
/opt/scada/ArchiveDAT
You can copy the data files to Windows and view them by the utility.
When I view the table on the web station the data is from the first acquired data, it does not change as if it is frozen.
This is odd. Could you provide a link to a screenshot?
MikhailModerator1. Search for browser kiosk mode. It’s already solved.
2-4. It would be useful. Agree with you.
5. Set event count to 0 in the web app settings.
Thank you for the idea.
MikhailModeratorI suppose, this update should be officially released soon.
but the register computer code is different from other computer code.
It’s not related to the module version.
MikhailModeratorIt’s a special format supported by Excel and Libre Office (XML Table 2003, Spreadsheet ML). It’s not XLS nor XLSX.
How money?
Please contact us by email to get an offer.
And we can proceed for free if you manage to open a connection.
First of all, check that the link, created by ln command, works correctly. You can check it by clicking the link in WinSCP, for example.
MikhailModeratorIf you mean this Rapid Gate Update, this is a good version.
By this link you can see:
ModRapidGate 5.1.1.1 (In development) - Fixed an issue when starting the moduleDoes the update work correctly?
