l
Viewing 15 posts - 1 through 15 (of 16 total)
  • #8325
    huang
    Question one: Failure of link plugin
    1、 Demand:Pass input and output parameters to the calling page through the link plugin
    2、 matter:
    (1) The first-level page uses the link control to bind the second-level dialog box according to View Id.The link property Input channels configures one or more input and output channel parameters. When the second-level dialog box is not configured, the second-level dialog box cannot display data and the command button of the dialog box does not respond.
    (2) No output channel
    3、Operation process:
    Configure link attributes on the first level page, as shown in Figure 1:
    Figure1
    https://ibb.co/v1KzyP4
    Figure 1 the first level page
    The secondary dialog box is displayed, as shown in Figure 2:
    Figure2
    https://ibb.co/FJq9JSZ
    Figure 2 the second level page
    Question two: The button plugin is not be pressed (set to 1) and pop up (set to 0) operations
    1、 Demand: Hope the button plugin supports pressing (set 1) and pop up (set 0) operations
    2、 matter:
    The page uses the button plugin to only configure the input and output channel parameters, and the type of sending commands. The button plugin cannot support both press (set 1) and pop up (set 0) events at the same time.
    3、 Operation process:
    Configure the button plugin properties, as shown in Figure 3:
    Figure3
    https://ibb.co/GdDXmSk
    Figure 3 the button plugin properties
    The operation button plugin has only close and open functions, no other button functions can be configured, as shown in Figure 4:
    Figure4
    https://ibb.co/6nMjWrd
    Figure 4 the button plugin function
    #8327
    When you specify ViewID to navigate by a link component, input channels are ignored.
    To use input channels as parameters, set ViewID=0 and set the URL property. For example, mypage.html?param1={0}&param2={1}
    where {0}, {1} are the indexes of the specified input channels.
    A button component supports only sending commands and opening charts. To open a popup use link component. You can change link properties to display it in button style.
    If you open the same view by clicking the explorer tree node, does it work correctly?
    Buttons for a command can be specified by editing the Output channel table of the configuration database.
    #8328
    If you mean 2 state button, like a toggle switch, use dynamic picture or toggle component.
    #8347
    huang
    Dear Mikhail,
    I have a new question to ask.
    Question:configure the link component, the second-level dialog box does not display data, and no pop-up box appears when the button is clicked.
    Operation process:Configure the View ID in the link component properties as the scheme index displayed in the secondary dialog, Input channels configure one or more input channel parameters, Target configure the popup, and the component properties of the secondary dialog will not be configured. As a result, the text component in the secondary dialog box does not display data, and the button component clicks without a pop-up box.
    Screenshots:
    Configure link properties as shown in Figure 1:
    https://ibb.co/4gVt6mt
    The secondary dialog box is displayed as shown in Figure 2:
    https://ibb.co/N7nBTzy
    Please show a correct example, preferably with a screenshot of the configuration steps.Thanks!
    #8348
    JW
    Link component doesn’t display data.
    you can add a few dynamic text to display data and dynamic picture to display icons, and align them under the link component.
    set z index them, depending on you preference of which one on top.
    #8358
    Please make a screenshot of the dynamic text properties that is located on the popup. Did you set the Input channel property of this component? It’s required to show values.
    #8362
    huang
    Not set the Input channel.Can’t the channel number of the data-input channels in the link component properties be passed as a parameter to the dynamic text component in the popup?
    #8381
    No. But scheme templates may help (scroll the page down to Scheme Templates).
    #8394
    huang
    Thank you for your help.
    The scheme templates didn’t help me.Can you develop or improve this function of passing parameters?
    #8421
    How many different input channels you need to open using this approach?
    Do you need to add several links on the parent scheme, and each link is open the same child scheme having corresponding input channels?
    #8433
    huang
    Hello,Thank you for your answer. We have solved this problem,but there are still questions for you.
    For the dynamic picture or toggle component,I do not mean 2 state button.I want a component that can execute 2 events with one click(as the example shown in Figure 1) at a time.Is there any component that realizes this kind of function at present, if so, how to use it, if not, can you please develop a button component with this kind of function?
    Figure 1:
    • This reply was modified 5 years, 3 months ago by huang.
    #8435
    huang
    https://ibb.co/N3Znhmj
    #8440
    Using Automatic Control Module it’s possible to send 2 commands by one button click. But scheme buttons can execute an action only on press down. For SCADA systems, especially web based, having 2 events (button down and button up) is a bad approach because it can cause sending wrong commands.
    What action do you need to run on such buttons?
    #8441
    huang
    Thanks, I want to implement the reset function.
    #8442
    huang
    For example, to control the state of the gate, when opening the gate, click the open button to close and then open; when closing the gate, click the close button to open and then close. Can these two actions be implemented in one action?
