Hi, I am new to Rapid SCADA and a quick search on the forum doesn’t land me on how to install Rapid SCADA on a Linux(Ubuntu) Server edition v20. A kick start on the installation process will be helpful
I have tried to install 3 times without success. The last time I even had someone else confirm the steps equalled the instructions.
Is there any chance you could produce a youtube for a Linux installation?
Wow….you need to slow down between typing the command and pressing the enter key. Also the first command you use….dotnet –info brings back an error….. Bash: /usr/bin/dotnet: cannot execute binary file: Execformat error.
Im guessing that Rapid SCADA will not work on Raspberry Pi? Debian Bookworm 64 bit. Is this correct and have I been wasting my time?
