Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Rpi 4 Rapid Scada web station table
- This topic has 6 replies, 2 voices, and was last updated 5 years, 8 months ago by
March 3, 2021 at 10:22 am #8390
Bill_A
ParticipantHi, I’ve got two independent Rapid Scada systems running. One on Windows 10 with no issues and now a trial running on a stand alone Rpi 4.
The Rpi 4 uses Softether to communicate to remote sites. At these remote sites there are Modbus TCP devices which Rapid Scada polls successfully. I can see accurate input data in Administrator.
When I view the table on the web station the data is from the first acquired data, it does not change as if it is frozen.
I have tried adding all access to the /opt/Scada/ folder and multiple reboots and uploads to the server. No change.
Where is the data stored before it is displayed on the web server? I have not setup and external database for this application but I have for the Windows 10 version.
March 4, 2021 at 3:17 pm #8410
/opt/scada/ArchiveDAT
You can copy the data files to Windows and view them by the utility.
This is odd. Could you provide a link to a screenshot?
March 6, 2021 at 3:46 am #8425Bill_A
ParticipantThanks Mikhail,
Further investigation as below.
– Communicator is communicating successfully with field devices. I’ve since change it to login into the server via 192.168.50.47 instead of localhost. I can see it is logging in successfully.
– The server log doesn’t show and issues.
– Viewing the archive in the Server – Hourly data is not updating and seems frozen. It’s as if the communicator has been sending the exact same piece of data since it started, even though the communicator see’s updated info?
– When I change a value on the service archive, I can see the change on the web interface.
I think the issue lies on the server somewhere and not saving updated information that it is receiving from the communicator. All files in archive folder have rwx+ugo
Hope we can solve this issue as I will have to move back to a small micro Windows PC….
Images
https://ibb.co/q50HsKt
https://ibb.co/ZM1TJQW
https://ibb.co/hYzKGZy
https://ibb.co/dcqCKFP
https://ibb.co/Hz04V9k
https://ibb.co/4tKSHLM
https://ibb.co/7Yp7T7XMarch 6, 2021 at 4:42 am #8426Bill_A
ParticipantFurthermore,
I have built this server on the demo version that comes with the project. I can see updated data gathering from the simulator.
March 7, 2021 at 7:30 am #8429
MikhailModeratorThis screenshot shows that the device tags are not bound to input channels. To do that make sure that the input channels were created and the Signal field of that channels > 0 (e.g., 41, 42, 43 and 44 according to the screenshot).
March 7, 2021 at 9:37 am #8430Bill_A
I see what you mean, I’m not sure how that happened, I since re-added the channels and it is working.
March 8, 2021 at 9:33 am #8439
MikhailModeratorGood 🙂
