Viewing 15 posts - 3,001 through 3,015 (of 6,219 total)
  • in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8787
    Dear Mr.Mikhail,
    The WebSettings.xml had been edited manually, but the result is the same.
    In this case you have no need to save it in the web interface.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8764
    You can also edit WebSettings.xml manually in the project using the Administrator app:
    <Script name="ChartScript" path="~/plugins/ChartPro/js/chartdialog.js" />
    in reply to: Communication stops on device timeout #8760
    You could increase the Reconnect parameter to 30 or 60, for example, to reduce latency when a device is offline.
    Also it can be a good idea to split polling into several communication lines that work in parallel.
    in reply to: Tracking state in formula, a bad idea ? #8759
                    // вычисление дорасчётных каналов, если добавленый срез изменился
                    if (changed)
                        CalcDRCnls(drCnls, newSrez, null);
    It’s important because historical slice (snapshot, “srez”) can be changed because of averaging.
    Anyway, in v6 we will remove averaging from the core logic and move it to separate formulas or module.
    in reply to: MQTT #8758
    First, try to connect public MQTT broker according to the video. Does a public broker works or not?
    The MQTT driver is difficult to diagnose.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8757
    Hi everybody,
    I would use PuTTY for remote command line.
    in reply to: Communication stops on device timeout #8749
    It takes time for waiting 192.168.95.112 at 08:07:43.
    I don’t see the 1st screenshot that may be contains communication channel properties. Could you post it again?
    in reply to: Retry scheme ? #8747
    Could you explain the question?
    in reply to: Tracking state in formula, a bad idea ? #8746
    I wonder why CalcDRCnls() has to be called after average calculation?
    Which line numbers of the source code do you mean?
    in reply to: Chart Pro with application error #8745
    “Method not found” error is caused because of Webstation version and the plugin version mismatch.
    The second screenshot: provide access right to all files in the config directory.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8744
    So Pls let me know how to uninstall Rapid Scada Software in Raspberry Pi?
    The uninstallation instruction is in the package ZIP.
    But I recommend not to uninstall Rapid SCADA, because you just need to fix file access rights. If you have issues with changing file access rights, post the related screenshots on the forum.
    in reply to: Communication stops on device timeout #8725
    Line Parameters – Main Parameters, then Communication Channel group box and the Properties button.
    it is waiting there for few seconds without communicating with other device which is still turned ON
    What date and time on your screenshot?
    in reply to: Loggin server error #8724
    Check C:\SCADA\ScadaServer\Log\ScadaServerSvc.log for the error details.
    in reply to: Capture Reading at a Certain Time of the Day #8723
    Use the formula:
    MonthBeg() ? Val(101) : Val()
    where 101 is the referenced channel.
    You can find MonthBeg implementation in the Formulas table if interested.
    The channel must be of the calculated real or calculated discrete type.
    in reply to: Chart Pro with application error #8722
    If you already did it, repeat.
