Forum Home › Forums › Runtime Bugs › Communicator Bugs › Communication stops on device timeout
- This topic has 8 replies, 2 voices, and was last updated 5 years, 7 months ago by
April 12, 2021 at 12:31 pm #8709
Jure
ParticipantI have two devices on communication line, both of them modbus. Everything works OK if both are working, but If i turn off one communication with it times out and whole communication line stops:
Should i change settings to prevent this, or what would be solution?
http://imgur.com/a/BP6llmoApril 12, 2021 at 1:34 pm #8712
MikhailModeratorOn the screenshot the line seems working.
Also please provide a screenshot of your communication channel properties.April 12, 2021 at 1:43 pm #8714Jure
ParticipantIf you look at last line it says:”Establish a TCP connection with 192.168.95.112:502″ it is waiting there for few seconds without communicating with other device which is still turned ON.
With turning off the device i mean turning off the simulator on some PC. Other device that is PLC is still working.With communication channel you mean this?
http://imgur.com/a/motJS49April 13, 2021 at 3:34 pm #8725
MikhailModeratorLine Parameters – Main Parameters, then Communication Channel group box and the Properties button.
What date and time on your screenshot?
April 14, 2021 at 6:09 am #8730Jure
ParticipantSettings:
https://imgur.com/Oz20xiYCommunication log:
https://imgur.com/TeDtNY0As you can see it takes 25 seconds between two reads. But it should read every second. So if I send command in this 25 second window it won’t be sent. Should every device be on it’s own line?
This reply was modified 5 years, 7 months ago by
Jure.
April 14, 2021 at 6:18 am #8732Jure
ParticipantSorry second screenshot was wrong:
https://imgur.com/a/XnMcZ6SApril 14, 2021 at 2:01 pm #8749
MikhailModeratorIt takes time for waiting 192.168.95.112 at 08:07:43.
I don’t see the 1st screenshot that may be contains communication channel properties. Could you post it again?April 15, 2021 at 6:13 am #8752Jure
ParticipantCorrect, it waits because 192.168.95.112 is offline. But because of that 192.168.95.10 is unresponsive.
I hope that properties work now:
http://imgur.com/a/mV5s7a3April 15, 2021 at 11:36 am #8760
MikhailModeratorYou could increase the Reconnect parameter to 30 or 60, for example, to reduce latency when a device is offline.
Also it can be a good idea to split polling into several communication lines that work in parallel. -
