What version of Elastic Report do you use?
What error do you get?
MikhailModeratorA checkbox that does what?
MikhailModeratorTry Notepad++, for example.
MikhailModeratorThe above link contains none of the requested info.
What version of KpMqtt do you use?
MikhailModeratorWhen Rapid SCADA is restarted, Communicator has no tag values and it sends empty data to the server.
Try the formula for an input channel:
CnlStat > 0 ? Cnl : Val(); CnlStat > 0 ? CnlStat : Stat()
It should keep the last good value.-
This reply was modified 4 years, 7 months ago by
MikhailModeratorAdministrator can import tables from DAT and XML format. These files must have correct format, for example be exported from Administrator before.
To generate channels, you can use XML format.
Could you make a screenshot of the Modbus template, device data page and copy request and response as text?
MikhailModeratorWhich file do you import? More info needed.
Fixed Y scale is not in the plan. Can by implemented by a contract.
MikhailModerator@cmdVal is a variable that contains value of the command being sent. The variable is filled by the driver.
MikhailModeratorPlease provide screenshots.
August 26, 2021 at 1:48 pm in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9440August 25, 2021 at 12:39 pm in reply to: Local Host Not Working (WEBSTATION NOT OPENING IN CHROME ) #9432
MikhailModeratorMake sure that IIS works by opening http://localhost/
Did you get any error messages during installation? -
