Syntax import to SQL server Forum Home › Forums › Understanding the Software › Syntax import to SQL server Tagged: SQL This topic has 7 replies, 2 voices, and was last updated 5 years, 3 months ago by Mikhail. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts August 25, 2021 at 3:07 am #9425 NguyenParticipant Please help me! Can you give me a correct syntax ? insert into Table_Test (Myfield) Values (@iTag1) @iTag1 : My tag of chanel input in Device1 https://ibb.co/Zg7jpH9 https://ibb.co/K5qrSPh This topic was modified 5 years, 3 months ago by Nguyen. August 25, 2021 at 3:14 am #9427 NguyenParticipant https://ibb.co/SfCDtTY August 25, 2021 at 12:01 pm #9428 NguyenParticipant Please help me! thanks. August 25, 2021 at 12:37 pm #9430 MikhailModerator Command example: UPDATE table SET column1 = @cmdVal WHERE column2 = @cmdNum You can find it in the driver description in Administrator. In your case insert into Table_Test (Myfield) Values (@cmdVal) August 25, 2021 at 1:06 pm #9433 NguyenParticipant Thank for you help! So what is the @cmdVa. Where can I find the @cmdVa ? August 25, 2021 at 1:13 pm #9434 NguyenParticipant syntax : insert into Table_Test (ID) Values (3) It is working. But I want myValues is Tag of Input chanel. August 25, 2021 at 5:48 pm #9435 NguyenParticipant Thank you very much! I can do it! August 26, 2021 at 1:51 pm #9443 MikhailModerator @cmdVal is a variable that contains value of the command being sent. The variable is filled by the driver. Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
