Forum Home › Forums › Installation Issues › SCADA-Web Installation › Local Host Not Working (WEBSTATION NOT OPENING IN CHROME )
- This topic has 11 replies, 4 voices, and was last updated 3 years, 3 months ago by
August 25, 2021 at 12:19 pm #9429
Sanjay
Participantwhen WE run the “software in Open in Web Browser” its showing “This localhost page can’t be found .No webpage was found for the web address: http://localhost/scada
HTTP ERROR 404”This Problem is arising in Internate Explore and Chrome.
NOTE: System is Windows 7/ Windows 10
This topic was modified 5 years, 2 months ago by
August 25, 2021 at 12:39 pm #9432
MikhailModeratorMake sure that IIS works by opening http://localhost/
Did you get any error messages during installation?August 26, 2021 at 4:05 am #9437Sanjay
ParticipantIts opening, no any error messages found during installation.
August 26, 2021 at 7:59 am #9438Sanjay
ParticipantStill is showing same message.
August 26, 2021 at 1:48 pm #9440December 3, 2021 at 7:45 am #9730gabeirinhas
ParticipantHello
when starting sw in the web browser
show me the error code
“HTTP Error 503. The service is unavailable.”Server status is normal
Communication with the ports is correct
I have installed manually
the problem continues
Can somebody help me
December 3, 2021 at 2:13 pm #9732
Please provide the info as follows:
1. What operating system is used?
2. Is the root page http://localhost/ available?December 3, 2021 at 2:26 pm #9733gabeirinhas
ParticipantGood afternoon
OS Windows 10 Pro 64-bit (x64)
Service Unavailable
December 3, 2021 at 2:35 pm #9734gabeirinhas
ParticipantIntegrity Check
Command types…OK
Command values…OK
Channel types…OK
Communication lines…OK
Output channels…OK
Event types…OK
Number formats…OK
Formulas…OK
Input channels…OK
Interface…OK
Devices…OK
Device types…OK
Objects…OK
Quantities…OK
Rights…OK
Roles…OK
Role inheritance…OK
Units…OK
Users…OK
The configuration database is correct.
Device 1 “Test device”
DLL : KpModbus
State : normal
Comm. session : 03/12/2021 15:30:27
Command : time is undefined
Comm. sessions (total / errors) : 567 / 0
Commands (total / errors) : 0 / 0
Requests (total / errors) : 1220 / 0
Current device tags data
| Signal | Name | Value | Channel |
| ******** HR NIVEL ********************* |
| 1 | LT1 | 562 | 101 |
No archive data
No events
////////////////////////////////////////////////////////////////////////2021-12-03 15:28:50 <MLG-++++++><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2021-12-03 15:28:51 <MLG-+++++++><SYSTEM><ACT> Writing snapshot in the current data table is completed
2021-12-03 15:28:51 <MLG-++++++><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2021-12-03 15:28:51 <MLG-JMGABEIRAS><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
December 4, 2021 at 10:47 am #9736
> Service UnavailableIf service is unavailable, IIS is not properly installed. The issue is not related to Rapid SCADA, you should fox IIS.
July 24, 2023 at 9:50 am #13033mm
ParticipantI managed to make V5 work. Now I tried programming the same program on V6 and everything is working except for the Webstation (http://localhost/scada). I installed the V6 exactly as indicated in the latest documentation. The only thing that was done differently was creating and saving the project in C:/ rather than with the installation package C:/Program Files/SCADA. I think IIS was installed correctly since I had no issue with the Webstation using the RapidScada V5. Also note that communication with device was established and live data can be seen.
When I access the Webstation logs, there are no logs to be seen (displays “No data”). When I access http://localhost:10008 (as indicated in the latest documentation), the usual login page is displayed but with the following error message:
Please correct the following errors:
The application is not ready. Try again later.It’s already been a while and the documentation indicates that it should be fine by refreshing the page after 10 seconds. What should I do next please?
July 25, 2023 at 11:04 am #13042 -
