Error Import Table
Forum Home › Forums › Understanding the Software › Error Import Table
  • #9439
    haitan981
    I want to import tag but show Error ” Error importing the ‘InCnl’ table : Key cannot be null. Parameter name: Key.
    Can you help me? Please!
    Thank you so much
    • This topic was modified 5 years, 2 months ago by Mikhail.
    #9442
    Please provide screenshots.
    #9444
    haitan981
    Which file do you import? More info needed.
    #9449
    haitan981
    it is .csv and .dat file . Because I want to edit .csv in Excel for creat a number of tags
    #9459
    Administrator can import tables from DAT and XML format. These files must have correct format, for example be exported from Administrator before.
    To generate channels, you can use XML format.
    #9470
    haitan981
    But I can not edit .xml file in Excel. What is software to edit .XML file for table to eazy
    xml file before and after edit and save in Excel
    screenshots2
    #9472
    Try Notepad++, for example.
