Mqtt communication doesn’t work at autostart
Forum Home › Forums › Runtime Bugs › Communicator Bugs › Mqtt communication doesn’t work at autostart
  • #9452
    Jure
    at server start I automatically start Mqtt Mosquito broker and Mqtt client which sends PLC data. At every server restart RP can’t open connection with Mosquito:
    Error reconnecting: Object reference not set to an instance of an object.
    I found out that to solve the error I need to restart communicator, after that it works fine.
    #9463
    What version of KpMqtt do you use?
    #9464
    Jure
    Last version from Github:
    It says that was created 10.5.2021
    #9475
    I will check and write in this topic.
    #9478
    Jure
    Maybe some more info that could help. We didn’t had this problem on Win10, but only now that we are using Win 2019 server.
    #9479
    Please provide the communication line log from server restart to “Error reconnecting” message.
    • This reply was modified 5 years, 2 months ago by Mikhail.
    #9481
    Jure
    I hope that this will be ok: https://pastebin.com/j9yFp0nG
    #9486
    It makes sense. Thanks.
    #9488
    Please try the KpMqtt update. Does it help?
    #9489
    Jure
    I made server restart and it works now. Thank you for quick response.
    #9490
