Viewing 15 posts - 2,581 through 2,595 (of 6,244 total)
  • in reply to: Контроллер домена #10147
    In the Server settings the Domain controller field is used for checking user names and passwords by Active Directory. Also ModActiveDirectory module should be activated.
    It’s not recommended to change TCP port which is used for data exchange between Server, Communicator and Webstation apps. The default port is 10000.
    in reply to: OPC DA #10144
    If the required value is array, you should set an array length.
    Channel names entered in the configuration database have no effect how Communicator reads data from the OPC server.
    Does the OPC manufacturer support OPC UA standard? OPC DA is outdated.
    I also have doubts about the ability of Rapid SCADA to communicate by standard DNP3 or IEC-60870-5/-104 with RTUs
    You need a 3rd party OPC server to use the mentioned protocols.
    in reply to: How to quickly add OPC channel #10141
    but it didn’t seem to work
    What exactly?
    in reply to: How to quickly add OPC channel #10140
    I think, you are on the right way.
    You can copy KpOpcUa*.xml and then edit it with XML editor like Notepad++.
    To find what lines should be edited, create 2 files manually, then compare them using WinMerge free app.
    in reply to: Контроллер домена #10136
    May be the translation of the question is not exact.
    Please explain what IP and port do you need to set.
    Note: please write in English on this forum. Also there is a subforum in Chinese.
    in reply to: Контроль доступа #10135
    Access rights are applied to a view like scheme or table.
    in reply to: Runtime Events #10128
    You could try the following:
    1. By default, there is a delay 200 ms after each request. You can set it to 100 ms in the device options, for each device.
    2. Split the communication line into 2 communication lines. They work in parallel.
    in reply to: OPC DA #10124
    Please upload screenshots to some cloud drive to be able to see them.
    in reply to: Runtime Events #10122
    Please provide screenshots of the Communicator settings and communication line log.
    in reply to: Sending Command values without password #10121
    1. Open https://localhost/scada/plugins/Config/WebConfig.aspx
    2. Untick “Require password to send command”
    3. Press “Save Configuration”
    4. Download configuration changes into your project by the Administrator app
    in reply to: Sending Command values without password #10117
    The required option to disable password is presented in the Web application configuration.
    in reply to: Send/Import data with timestamps from a driver #10114
    I can’t understand Rapidcada structure yet
    Ready to help if you ask more questions.
    in reply to: Rapid SCADA 6 Beta #10113
    Hello Matt,
    Thank you for the bug report. It is fixed now, and the fix will be included in the next beta release.
    Currently, you could manually edit a path in C:\Users\YOUR_USER\AppData\Local\ScadaAdmin\Config\ScadaAdminConfig.xml
    in reply to: TCP Api #10110
    To open some web page automatically, you need an application that runs with a user account. Server runs as system service, so it’s not possible to start any UI from formulas.
    in reply to: config file hot reload #10107
    We plan to develop a module that allows to change the following configuration in runtime without restarting:
    1. Users
    2. Channel limits
