Контроллер домена
Forum Home Forums Uncategorized Issues Контроллер домена
  • #10134
    hengyang
    Существуют ли какие-либо руководства, связанные с управлением доменом? После установки IP и порта для сохранения, как проверить, подействует ли это?
    #10136
    May be the translation of the question is not exact.
    Please explain what IP and port do you need to set.
    Note: please write in English on this forum. Also there is a subforum in Chinese.
    #10146
    hengyang
    There is a connection in Common Parameters to set domain control information
    I set the TCP port and Domain controller information according to my domain control environment and save it
    How can I use my domain control account to log in after saving? Is there a Domain controller configuration manual related to Rapid Scada?
    #10147
    In the Server settings the Domain controller field is used for checking user names and passwords by Active Directory. Also ModActiveDirectory module should be activated.
    It’s not recommended to change TCP port which is used for data exchange between Server, Communicator and Webstation apps. The default port is 10000.
