MQTT – period must be less than 65 seconds
Forum Home › Forums › Runtime Bugs › Communicator Bugs › MQTT – period must be less than 65 seconds
  • #17890
    WayneS
    Greetings
    When I try and run a MQTT publisher it works 100% when the period is less then 65 seconds. When it is greater then 65 seconds I get errors when attempt to publish:
    Error:Index was outside the bounds of the array
    When the period is 2 minutes every second attempt to publish fails with the message above.
    Any suggestions on how to work around this.
    Ideally I would like to publish 5 topics at 5 minutes then 35 minutes etc..
    regards
    Wayne
    #17891
    Please provide screenshots of driver settings and log files, containing the above error.
    #17893
    WayneS
    Hello Mikhail.
    Screenshoots:
    https://ibb.co/qMbS10D1
    https://ibb.co/BH7wSg53
    https://ibb.co/M5KKjwwv
    One shows the driver settings, one is the log just after restarting while the last is the log sometime after starting showing errors.
    regards
    Wayne
    #17895
    Thank you for the screenshots.
    I’ll check and write in this topic.
    #17903
    Please try this update. Does it work?
    #17908
    WayneS
    Hi Mikhail,
    I downloaded the update and copied the files into my “program files/SCADA” directory. I checked that the files had been replaced. I then uploaded the project and changed the publishing times. At 1 minute, it worked well. At 2 minutes, every second one failed.
    regards
    Wayne
    #17910
    There was an invalid file path in that archive. Sorry.
    Move DrvMqttPublisher.Logic.dll from the ScadaComm directory to ScadaComm\Drv or use this archive.
    #17918
    WayneS
    Hi Mikhail,
    Thanks, that’s working well now.
    regards
    Wayne
