Viewing 15 posts - 2,281 through 2,295 (of 6,243 total)
  • in reply to: More ‘native’ scheme editor #11172
    A web app seems like the better option due to being cross-platform. However, implementation of property editor is tricky.
    • This reply was modified 3 years, 6 months ago by Mikhail.
    in reply to: communicator question #11171
    Will communicator send all device tags while we restar the server and communicator ?
    When Communicator starts it sends all tags for each device after a session with it.
    If Server restarts, it does not affect sending all data or changes only.
    Do we have any Interface to access the communicator state?
    In version 6 device status can be bound to channel.
    in reply to: Long loading times of schemes #11170
    that scheme is loading for really long time
    When loading takes a long time, is loading result successful?
    Try to open the same scheme on Windows Server and compare with other machines.
    Check the size of the scheme file.
    in reply to: export event data to postgres #11169
    ModDbExport_001.txt says that only events are exported, because the queues for current and archive data are not in use. You should check the module configuration.
    in reply to: Webstation plug in (no record) #11007
    You should check that the key file PlgNotification_Reg.xml is located inside your project in the C:\SCADA\Projects\YOUR_PROJECT\Instances\Default\ScadaWeb\config folder
    in reply to: export event data to postgres #11006
    Please provide log file without download. Publish it on Google Drive or copy error here.
    I forgot to mention that I am testing rapidscada in a vmware virtual machine do you think that is a problem?
    VMware is OK.
    in reply to: ModAutoControl_Reg.xml not found. #11005
    Check that ModAutoControl_Reg.xml exists inside the project.
    Also check that the keys are not ignored on the project upload form.
    Keys files are transferred when a project is uploaded to server.
    in reply to: Rapid SCADA 6 Beta #10999
    For the next beta update we should at least add historical and event reports. Currently the work is in progress.
    in reply to: export event data to postgres #10998
    MdDbExport_xxx.log that connection to database cannot be established. Check connection settings. The full error message is not visible on the screenshot.
    in reply to: If and then implementation #10994
    Please find the project file for review as below
    Project review is out of the support.
    Please ask particular questions.
    Please provide a screenshot of Notification plugin that contains visible notifications.
    Still don’t see it.
    in reply to: Notification installation and start #10993
    Configuration of plugins is a part of Rapid SCADA project. XML files should be located in the project.
    If you changed plugin configuration file in the project, you should upload it to the server to run.
    in reply to: Webstation – Web Application Configuration #10992
    All that settings are inside your project. Restore the project from your backup and upload to server.
    Reinstallation is not needed.
    in reply to: Quantites and Units #10990
    The Quantities table contains physical quantities.
    The Units table contains units of measurement, and may contain enumeration values.
    For example, 10 meters.
    Quantity is length.
    Meter is unit.
    in reply to: Profile and secret key #10989
    You can copy correct secret key from C:\SCADA\ScadaAgent\Config\ScadaAgentConfig.xml
    in reply to: Event types #10988
    Yes, you can add custom statuses. To use them, you need formulas that return corresponding statuses.
    The Units table does not contains channel statuses. It may contain enumerations.
