MikhailModeratorThere are a lot of online SMS services depending on country.
Xml Content Translator may be quite useful to create automatic translations to many languages.What are the differences between source and modified Xml Content Translator?
Do you know if this app uses external or internal engine for translation?
Is it possible to translate, for example, ScadaWeb.en-GB.xml by a few clicks?
Please provide screenshots that illustrate the question.
MikhailModeratorIf Server is not available, check the log file of the Server service.
October 10, 2022 at 1:38 pm in reply to: Notification plug in (trial key vs paid registration key) #11215
MikhailModeratorthere is no acknowledgement sound alert when the status of the defined registered is changed
Press F12 to check browser error messages in the console.
October 10, 2022 at 1:37 pm in reply to: Notification plug in (trial key vs paid registration key) #11214
Permanent and trial keys work similar. If some function does not work as expected, it is not caused by using trial key.
The described issue is fixed in Rapid SCADA 6.
In version 5, as a workaround you could locate a home scheme in the subfolder.
You can check application log files via the Administrator app.
MikhailModeratorThat is really interesting. Thanks a lot!
I will try to build Rapid SCADA using your description. I will write about my experience in this topic.
If you decided to make a guide with screenshots as a Word, Libre Office or Google document, it may be useful to save information.
MikhailModeratorCould you provide more details how you’d like to see it?
MikhailModeratorI confirm that sometimes the described issue happens. Likely it is caused, when data request has no response from server. We will fix this issue when start redesign of schemes in the next generation of scheme engine.
MikhailModeratorIf a post contains a lot of hyperlink, it can be automatically blocked by the forum protection system. Sometimes, it’s more handy to provide a one link to Google document for example.
I found and accepted your post.
MikhailModeratorNow I can access SCADA API from Node-RED easily.
Cool!
MikhailModeratorYes.
Add an extra channel for a device, set its TagCode to Status and Format to Device status. -
