Viewing 15 posts - 211 through 225 (of 6,218 total)
  • in reply to: Custom Command #17251
    2. In the Modbus template, add a new command, set the Data block to Custom, the function code to 7.
    3. According to the Modbus specification, Input Registers are read-only. So it’s not possible to write them. You can try creating a separate command with the 0x06 code.
    in reply to: OPC DA to OPC UA Server Question Communicator #17250
    > I was able to get your software to recognize an OPCUA server and its all working now.
    That’s nice.
    > if I want to work on an project on one PC and then copy it over to another PC how do I do that?
    Please create a separate topic for that question.
    in reply to: Can RapidScada act as an OPCUA server #17248
    Yes, activate the OpcUaServer data source that can be found in Instances – Default – Communicator – Data Sources.
    • This reply was modified 5 months ago by Mikhail.
    in reply to: memory problem #17241
    That problem has not been observed before.
    What versions of the web browser and Rapid SCADA do you use?
    in reply to: modal develop in mimiceditor #17236
    It would be useful, but this is not possible for now. I saved the idea and will see what can be done. I plan to return to work on the new editor in January.
    in reply to: Some channels muted in Notifications #17235
    Creating a channel is just writing its properties into the XML file.
    To find a cause, it would be useful to analyze the channel properties and events.
    in reply to: Failed to fetch. #17232
    > So if this issue occurs, should we address it or simply ignore it?
    If the issue is not visible to a user, it can be ignored.
    in reply to: OPC DA to OPC UA Server Question Communicator #17231
    System requirements are here.
    Minimum Windows 10.
    Can I connect to it using Rapidscada to access the OPC data on that machine?
    Likely, yes.
    in reply to: Automatic Control Module – Registration key invalid #17230
    If you have any issues, please contact us.
    in reply to: Is there a better way to batch modify channel attributes? #17225
    In the Administrator app, select Tools – Project Tools – Export Table. Then select an output format, and channels to export.
    in reply to: Failed to fetch. #17224
    Do the errors occur when a new table view is open, or when a table view is unloaded?
    Also please make a screenshot of the error requests in the Network tab.
    in reply to: Some channels muted in Notifications #17222
    Notification Plugin creates notification based on events that require acknowledge.
    I suggest to compare corresponding events in the bottom event panel to find differences between the events that cause notifications and other events.
    in reply to: OPC DA to OPC UA Server Question Communicator #17221
    Perhaps, you need a central Rapid SCADA instance to collect data from all PCs.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #17215
    in reply to: Failed to fetch. #17214
    To insert an image, please use a 3rd party image hosting. Maybe screenshot of the Network tab can clarify the situation.
