Viewing 15 posts - 2,056 through 2,070 (of 6,240 total)
  • in reply to: Chart Pro Trend Colors #11828
    Sorry, I checked the manual https://rapidscada.net/docs/en/5.8/modules/plg-dashboard and found that you can specify chart configuration file for v5 also. Please choose a method that is more comfortable for you: specify axes in the single file or create many files. Or combine the both methods.
    • This reply was modified 3 years, 3 months ago by Mikhail.
    in reply to: Chart Pro Trend Colors #11826
    Thank you for the photo.
    Chart Pro for version 5 has a single configuration file. To set different colors for different quantities, you can define new YAxis with the specified Quantity ID in PlgChartPro.xml.
    Chart Pro for Rapid SCADA 6 may have multiple configuration files. You can use the above method, or create different configuration files and specify them for dashboard. But, for now Dashboard Plugin for version 6 does not exist. So I wrote the 2nd method for the future use.
    in reply to: v6, mqttnet upgraded from 3.1.2 to 4.1.4.563 #11825
    Thank you for the info.
    I’ve added the dependency upgrade to the task list.
    in reply to: Edit popup size #11823
    There is no particular size option because this is how Bootstrap popups work.
    Do you use Rapid SCADA 5 or 6? What screen resolution?
    in reply to: Version 6 issues #11822
    Make sure that the Agent service is running without errors by checking its logs.
    in reply to: OPC UA data limit #11821
    If you need some help with that, provide screenshots and logs.
    in reply to: Internal server error (500) #11820
    Make sure that AspNetCoreModuleV2 is installed like described here.
    in reply to: Chart Pro Trend Colors #11810
    Could you provide a link to a screenshot of your existing dashboard? It would help to understand the issue.
    in reply to: Version 6 issues #11808
    That’s true, Rapid SCADA 6 is significantly different than version 5. It’s more simple and handy. Documentation will be added on https://rapidscada.net/docs/
    Currently, there are instructions how to install the new version. Configuration manuals will be created after porting the existing modules, drivers and plugins.
    in reply to: What is the default Password in version 6 #11802
    Use EncryptPassword from this folder.
    In the next version of the Administrator app, there will be a UI feature for encrypting passwords.
    in reply to: V6 plug in #11801
    The keys can be updated for free for the same computer.
    in reply to: Bulk Creation of Devices and Communication Lines #11795
    You should reopen the project to read the changes in the tables.
    in reply to: OPC UA data limit #11794
    Thank you for the update.
    May be it would be more comfortable if you create separate devices (like CONTROL_2 etc.) on the same communication line. I mean if they related to different physical devices.
    in reply to: RAPID SCADA WINDOWS FEATURES REQUIERED #11793
    Hello Tony,
    There are no special recommendations.
    Please use Microsoft docs for installing IIS on Windows server.
    in reply to: ScadaClient.GetSlice #11787
    Every execution of the above code a client requests different data points. Probably, they don’t exists. Try specifying particular timestamp.
