Viewing 15 posts - 631 through 645 (of 6,387 total)
  • Mikhail
    If you restart an OPC DA communication line (using the Administrator app), does a connection repair?
    in reply to: modbus与lora网关通信 #16415
    This topic is related to Modbus. Please ask about MQTT in a proper topic.
    in reply to: modbus与lora网关通信 #16413
    Rapid SCADA supports both Modbus and MQTT. Device polling is configured manually. If it’s needed to automatically recognize new devices, you should develop some additional module for Rapid SCADA.
    in reply to: modbus与lora网关通信 #16410
    Lora is a very common name. You should check the documentation of your Lora gateway and find information how it can provide data for the SCADA software. May be it can work in transparent mode so you could receive data in Modbus format.
    in reply to: about select channels #16405
    I’ve added that feature to the backlog.
    in reply to: about select channels #16403
    Do you mean that channels should be searched recursively under a parent object?
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #16401
    You can try to build and activate 2 plugins: PlgMimic and PlgMimicEditor. But they are on early stage.
    When they are ready enough, I will publish a demo.
    • This reply was modified 1 year, 5 months ago by Mikhail.
    in reply to: Table format for web view #16399
    You could try to insert an Elastic Report in HTML format as a web page view.
    It will display what you need, but without automatic refresh.
    in reply to: covert channel #16398
    > When the channel value is 0, the channel will not be displayed in the table.
    Table view cannot switch channel displaying.
    In a scheme view, it’s possible to change an image depending on channel value, so it will solve the question for discrete channels.
    in reply to: V6 Automatic Login feature #16389
    Automatic login is the same for the entire web application.
    To use another login/password, deploy an additional instance of the web application. It can be done on the same or another computer.
    in reply to: Disconnect from OPC DA server #16388
    > Rapidscada and the OPC DA Server are running on different machines.
    When OPC DA server and client are installed on different machines, it requires setup of DCOM security. You should search for DCOM manuals. Sometimes a user manages to run it.
    I recommend installing Communicator on the same machine where the OPC server is already installed.
    in reply to: Table format for web view #16385
    Schemes can display current data as a table. However, it requires manual data binding between cells and channels.
    in reply to: Event marker not found #16384
    Received. What hardware, operating system and file system is used?
    in reply to: Event marker not found #16381
    If writing an event is not properly finished because of power outage, new events will be successfully written in the file when server continue operating.
    An exception situation like “Event marker not found” occurs when an event file is corrupted, i.e. contains invalid data.
    If you need this issue solved, publish the corrupted file to be possible to analyze it it’s possible to restore them or not. If the problem occurs often, a special module can be developed to check and restore corrupted event files before the Server service starts.
    in reply to: XML Content Translator for SCADA 6 #16380
