Viewing 15 posts - 4,831 through 4,845 (of 6,391 total)
  • in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4023
    If you have some experience with Win 10 iOT, please share your opinion.
    in reply to: Install exe. file Rapid Scada on Raspberry PI 3 #4022
    Answered here.
    in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4021
    I suppose, the special port of Rapid SCADA should be implemented for Win 10 iOT. This is not a normal operating system, it has restricted .NET Framework and usual applications don’t work on it.
    To be honest, I don’t think this is a good idea, and I don’t see the future of Win 10 iOT. May be I’m wrong.
    in reply to: Responsive Web Design #4020
    I will check and write here.
    in reply to: String Length limit in Scada Admin #4019
    If possible, make a file name shorter. You can edit the table structure in ScadaBase.sdf file and change the field length, but it is not recommended.
    The issue is known, in a new version of a database the field will be longer.
    in reply to: Numerical display is wrong #4018
    If you have a formula for an input channel, it affects. You didn’t provide a screenshot of the input channel, so I’m not sure.
    in reply to: Responsive Web Design #4008
    How to reproduce the issue on my side?
    in reply to: Numerical display is wrong #4007
    The single digit display cannot be 0.2.4.6~…..
    Ten digits display normal
    I don’t understand the question. Could you explain?
    in reply to: Export to Database Module #4004
    In the Current Data tab you need to enter INSERT request only. Other SQL scripts are needed for creating the database.
    in reply to: Remote commumicator #4001
    rsepulve,
    it would be clear if you provide screenshots of your settings.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4000
    IP address of a GSM device is specific to a telecommunication company. Sometimes they provide real IP for extra fee. This approach is not flexible. That’s better when a modem connects to a server.
    IP addres I have to put in coomunication settings dor slave devie?
    IP not needed if a modem initiates a connection.
    in reply to: Export to Database Module #3997
    You should provide screenshots of the module settings and log of the export module.
    in reply to: Events not being fired #3996
    Thank you!
    in reply to: Events not being fired #3993
    Wow!
    Could you show the screenshots before and after?
    The above screenshot is too small. I can’t recognize anything.
    in reply to: Export to Database Module #3992
    1. Go to the Modules page
    2. Click the Add (+) button
    3. Add ModDBExport.dll and apply the settings.
    4. Select the module and click the Properties button.
