Create a new input channel of calculated type which uses a formula to calculate a number of color. Then use this channel in a scheme component to switch led color.
Now the only problem is finding a good way to remove old data in Postgres since it does not yet have the MySQL events functionality.
Could you send a link to an example of MySQL events? How do you use events for removing old data?
Thank you for useful solution.
Related to this topic you created.
I hope this advice will solve your issue.
You should press F12 in browser, go to the Console and Network tabs and make a screenshot of the detailed error message.
MikhailModerator
Could you illustrate the issue #1 by a screenshot?
MikhailModeratorI agree that this is an important issue. Thanks for paying attention to this.
MikhailModeratorI asked for a screenshot but I see *.json file.
I sent you an email.
MikhailModeratorIs there a method like Connect to connect to the OPC server?
MikhailModeratorThere is no screenshot by this link. At least on my PC.
It affects hourly table views.
When you see “rockets” at http://demo.rapidscada.net/View.aspx?viewID=22 near Light and Aeration, this is because of this column.
MikhailModeratorI suppose the URL here is the ID of the OPC server, e.g. Matrikon.OPC.Simulation/{f8582cf2-88fb-11d0-b850-00c0f0104305}
MikhailModeratorPlease make a screenshot of the browser console (Press F12 in browser).
