Viewing 15 posts - 4,531 through 4,545 (of 6,391 total)
  • in reply to: ScadaCommShell has problem with IChildForm #4844
    You should also refresh dll repository. WinControl.dll changed.
    in reply to: DataAccess API #4840
    1. Create your own database that contains user credentials.
    The database model is up to you.
    2. Create a module for SCADA-Server that checks user login and password.
    Use ModActiveDirectory as a template.
    Override ValidateUser method.
    3. Create a plugin to manage users.
    This is a plugin for Webstation that implements editing your database.
    Plugin examples are here.
    in reply to: Problem when installing #4839
    You should remove Rapid SCADA using the ScadaSetup.exe
    Make sure that C:\SCADA doesn’t extist after uninstall.
    Install Rapid SCADA again.
    in reply to: Mobile client and Rapid SCADA #4835
    I’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
    Is manjey73 said, VPN is the most preferable and safe way.
    Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scada
    OK, I added the author to email thread. Hope he will answer.
    in reply to: Error data fire system #4833
    Hola
    00 00 00 00 00 06 F6 03 00 00 00 05
    F6 is a unit ID, in terms of Rapid SCADA this is a device address defined in Administrator.
    While another software uses Unit ID = 1.
    You can check it by http://modbus.rapidscada.net/
    First of all, change the device address to 1.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4816
    I suppose, you should provide links to screenshots of your settings and copy communication log here.
    in reply to: 5.6.0 Web is not normal #4814
    I can connect to your PC remotely and fix the issue. This is a commerical service. To get it, please contact us by email.
    in reply to: Formulas Math Functions #4813
    How can I do this?
    For example, Cnl * 10
    is it possible to implement a digital momentary start/stop?
    Please clarify the question.
    in reply to: How to install rapidscada in Windows xp OS? #4812
    Rapid SCADA requires .NET Framework 4.6 or higher. You need at least Windows 7. See this
    in reply to: 5.6.0 Web is not normal #4808
    There was no changes in the project format. To get more error details, press F12 in a browser and watch the Console tab.
    in reply to: How to install rapidscada in Windows xp OS? #4807
    I’m afraid that Windows XP is too old. You can’t install .NET Framework 4.6 on XP that is required for Rapid SCADA.
    in reply to: 5.6.0 Web is not normal #4804
    After the update,paste the old project.
    Did the problem appears only when you apply the old project? Does it work after clear installation?
    in reply to: Ubuntu Installation Forbidden from Apache2 #4803
    Thanks for the solution ))
    Also the web site referenced in the install_with_apache.txt file does not resolve
    That’s true. That’s why there is a ready file scada.conf in the distributive package.
    in reply to: Function 05, Force single coil #4797
    Check Commands enabled checkbox of a communication line. If it doesn’t help, copy communication line log here in a moment of sending command.
