Forum Home › Forums › Understanding the Software › Intergration data input into cloud system
- This topic has 12 replies, 4 voices, and was last updated 8 years, 2 months ago by
February 22, 2018 at 3:01 am #3209
Hakim A
ParticipantHello there, so how am i going to solve the integration of rapid scada for the data input into the cloud system ? Is there any like a source code that i can use or anything?
This topic was modified 8 years, 7 months ago by
February 22, 2018 at 5:59 pm #3214
Cloud system is an abstract term. You can build your system based on Rapid SCADA or use other software and integrate it with Rapid SCADA. First of all, you should choose the architecture of the system.February 24, 2018 at 3:49 pm #3223Hakim A
ParticipantHi Mikhail,
Please understand that i am very new to all of these.
Here is my problem:
This project is to show if there is a leak in the pipeline. I have successfully display the minor leak and major leak scenario in the Rapid Scada scheme.https://drive.google.com/drive/u/0/my-drive
So right now how am i suppose to build the system based on Rapid Scada and how do i choose the architecture of the system? I am a little bit slow regarding all of these .
Please help me step by step.
Thank you for your response
Regards
HakimFebruary 26, 2018 at 2:11 pm #3232
MikhailModeratorHi Hakim,
Please provide correct links.February 27, 2018 at 2:56 pm #3237Hakim A
ParticipantFebruary 28, 2018 at 4:53 pm #3242
If you ask about displaying data on arrow indicators, currently it’s a bit tricky. Otherwise, clarify the question.
See the Manometer example https://rapidscada.org/download/image_pack/image_pack_1.0.zipMarch 5, 2018 at 4:17 am #3249manraj
ParticipantHi
I would want to purchase the RAPID SCADA services.But before that I would want to how would you connect to the modbus.Do I require a server room or only just WIFI?.Do I need to configure any settings.
March 5, 2018 at 2:17 pm #3250
You should use a device like Moxa Nport that initiates a connection with a cloud server by IP or DNS name. After connection is established, Rapid SCADA server polls the devices.March 5, 2018 at 5:03 pm #3251
MikhailModeratorAlso see
Moxa MGate
3grtack GS828March 16, 2018 at 3:28 am #3287manraj
ParticipantHi there,
I would want to ask if there is any other cloud systems which is open source that RAPID SCADA can access to.Perhaps a suggestion on a few cloud monitoring sites that I can look into.Is there a way where arduino board can send data to a cloud server and use RAPID SCADA to monitor it?.
March 16, 2018 at 2:19 pm #3293
Rapid SCADA can upload data to a database. If a 3rd party cloud system supports DB integration, you can use it.Is there a way where arduino board can send data to a cloud server and use RAPID SCADA to monitor it?
Yes, you should add into Arduino sketch one of the supported protocols: https://rapidscada.org/product/connectivity-and-integration/
And deploy Rapid SCADA into a cloud.August 14, 2018 at 9:20 am #4133trauden
Rapid SCADA can upload data to a database in clound bys this similar way.
Raspberry->NodeRed->Ubidots clound ?
http://help.ubidots.com/developer-guides/connect-node-red-with-ubidotsAugust 14, 2018 at 2:08 pm #4137
Likely, an integration software module should be developed to complete this task. -
