Viewing 15 posts - 3,226 through 3,240 (of 6,392 total)
  • in reply to: Interface reverted to older version #8624
    There is not enough information. Please provide screenshots.
    in reply to: Data not coming in Realtime #8622
    Please provide communication line log.
    in reply to: MQTT Sub String #8621
    Input channels are stored as 64-bit floating point numbers. I’m not sure that it’s possible to write much more than 8 chars into 64 bits.
    in reply to: Sending On / Off Commands to Modbus Register #8620
    OK
    in reply to: about SCADA V6 #8612
    We already made a mistake when developed on Silverlight. I guess, Blazor is an reincarnation of Silverlight ))
    in reply to: about SCADA V6 #8609
    In Rapid SCADA v4 we used MSSQL Compact for storing configuration database. It is very close to SQLite. This approach was so inconvenient. I agree that SQL is a powerful language, but comparing pros and cons, the file based projects that can be easily uploaded and downloaded are preferable.
    It’s possible to use an RDBMS instead of BaseDAT\*.dat as a runtime data source. We will implement it if found a sponsor.
    in reply to: SCADA V6 #8607
    v6 is a high priority project, it will be continued for sure.
    However, we provide fixed due dates only in case of working on a contract.
    in reply to: scheme view stuck with loading animation #8606
    This issue is interesting and unusual. Considering the fact that we anyway will rewrite the entire web application, I suppose, we should check the new web app if this issue still occurs and then fix it.
    dotNET5 doesn’t support WebForms technology that is currently used that’s why we have to create the web app from scratch.
    The subnodes are the channels grouped by device. That’s why subnodes are the same. All devices are displayed.
    in reply to: Accessing Scada.Client.DataAccess() #8603
    In formulas, only limited amount of information is accessible. To access to the configuration database and archives, you need to develop a module using C#.
    in reply to: scheme view stuck with loading animation #8592
    Yes, the issue is reproduced. But demo server has very low CPU and RAM.
    What are the parameters of your server? Is it Linux or Windows?
    in reply to: API for Integration #8591
    As an option, I would develop a utility to export XML and/or DAT files to the required RDBMS.
    in reply to: about SCADA V6 #8590
    If we found a sponsor, we can implement uploading a project from Administrator to PostgreSQL database.
    In my opinion, SQLite is not enough, because remote access is quite useful in many cases.
    in reply to: Silent server crash #8588
    Yes it is, see v5.1.4.2
    Server update for testing.
    The command queue is in the Server service.
    • This reply was modified 5 years, 6 months ago by Mikhail.
