Forum Home › Forums › Runtime Bugs › Webstation Bugs › Interface reverted to older version
- This topic has 12 replies, 2 voices, and was last updated 5 years, 7 months ago by
April 1, 2021 at 12:26 pm #8619
Jure
ParticipantHello,
we are creating a test scenario for SCADA. I had created two interfaces. One is working OK, but with the second I had problems since I had made it. From time to time when I update it and open it in browser as a client, it reverts to the status that it has one first save.
It helped if I saved it again and refreshed the web page of client. But then I closed the editor and it again reverted all the changes. So I reoponed editor and it has also reverted to the older version. What could be the cause for that? I checked the interface file size and there should be more in that interface file then just 1 button.Another question, is it possible to hide the left sidebar with the main menu and views for user?
April 1, 2021 at 12:48 pm #8624
There is not enough information. Please provide screenshots.
April 1, 2021 at 1:02 pm #8626Jure
ParticipantThis is how the interface currently looks:
https://imgur.com/a/WvMuQ6BBefore I had around 30-50 elements on interface. But when I uploaded new version of interface it reverted to old one.
Before it looked similar to this:
https://imgur.com/a/OgQJ2oeLike I said before, element disappeared when I uploaded new version of interface.
April 2, 2021 at 1:54 pm #8633
MikhailModeratorIf you change interface to the old version, does the element appear again?
April 7, 2021 at 6:16 am #8657Jure
ParticipantI don’t have the old interface anymore. Because when I made changes I saved them to the same interface file.
April 7, 2021 at 9:58 am #8659Jure
ParticipantI recreated the interface and everything was OK. I made backup copy for both of my interfaces inside the “Inteface” folder.. After that I made some changes in administrator and uploaded complete project and interface was overwritten again. Besides that both backups were deleted.
is it possible that there is huge bug or am i doing something wrong?April 7, 2021 at 12:26 pm #8664
MikhailModeratorBesides that both backups were deleted
Backups usually copied to GIT or separate drive. Also you could copy a project into C:\SCADA\Projects directory.
C:\SCADA\Interface directory is automatically cleared when a project is uploaded. This is an expected behavior.
April 8, 2021 at 10:05 am #8670Jure
ParticipantWell I didn’t know that it is automatically cleared and this is just a test project, so that we can see if this software fits our needs.
I managed to find the reason for problem:
If I copy elements from interface 1 to interface 2 and save interface 2, everything is ok.
But if I upload whole project, then all copied elements will get deleted. Even if I copy copied element. And since I wanted my elements to look the same in interface 2 as in interface 1 all elements were copies.
Is it possible to fix this? Because it easier to build new interface if you can copy elements from existing interface, especially if you want them to have same design.April 8, 2021 at 10:24 am #8671Jure
ParticipantIt must be something else, I crated new elements by hand and they again disappeared on upload.
April 8, 2021 at 10:31 am #8672Jure
ParticipantI understand now what is the problem, i was editing files in interface which is built from project/interface.
April 8, 2021 at 2:39 pm #8678
MikhailModeratorIf you describe how to reproduce an issue from scratch, we will fix it.
April 9, 2021 at 6:11 am #8685Jure
ParticipantIt was my error. I opened with editor file in SCADA/Interfaces instead inside the project. So when I saved the file it would show changes on website. But when I built the project again and uploaded it to server it has overwritten changes.
April 9, 2021 at 1:12 pm #8696
MikhailModeratorI suggest edit configuration only from Administrator. It helps to avoid such errors.
