Sending On / Off Commands to Modbus Register
Forum Home › Forums › Communicating with Devices › Modbus › Sending On / Off Commands to Modbus Register
  • #8613
    Bill_A
    I’m having trouble figuring out how to send On / Off commands to a Modbus Bool register.
    I have a single button to toggle the command, it works perfect when I enter in 0 or 1 then send the command however I’m wanting to have the option for On / Off instead of entering 0 or 1.
    I’ve configured the output channel to have ‘Command Values’ Off – On’. I get the display boxes when I click the button on the scheme but it does not send the message correctly to the modbus register. It comes up with fault. Error illegal command.
    I’m sure this is something simple and have tried different combinations to make it work. Surely I don’t have to write a formula to say If Off then = 0 or If On then = 1 for a simple on / off button?
    https://ibb.co/b7Tn7qH
    https://ibb.co/M7hpTyC
    https://ibb.co/NKDRzvq
    https://ibb.co/LprMzLr
    TIA
    #8614
    Bill_A
    Disregard, I found a issue with a specific modbus register I was trying to alter.
    #8620
    OK
    #9768
    gabeirinhas
    I am trying to activate a bit through a button.
    I don’t know what I’m doing wrong in the configuration
    Can you help me please
    attached photos
    https://www.mediafire.com/file/mv9wahbevj4c9pt/modbus.rar/file
    #9772
    Downloading RAR archives is not secure. Could you demonstrate the existing settings in this thread?
    What type of Modbus register do you need to set: coil or holding register?
