Viewing 15 posts - 3,136 through 3,150 (of 6,392 total)
  • in reply to: Developer in India #8887
    Maybe you should train your Rapid SCADA engineers and become our partner in India.
    in reply to: 65535 limit #8886
    How should I change the source code?
    It would be a huge change of source code. Otherwise, we got rid of this limit long ago.
    The v6 will support more channels.
    in reply to: How to get string value from Database #8876
    If string values are static, it’s possible to return a number from SQL request and then display it as a string (for example, Off and On values).
    in reply to: How to get string value from Database #8875
    it seems only a few characters is obtained, not the whole string value
    It supports 8 Latin characters per input channel.
    Actually this statement would get a result set,but only the first record is shown, the following records are missing.
    You right. The idea of the driver is to get a single row of current data.
    If you need to update the existing driver to be able to get data from a row set, we could discuss the requirements and cost.
    in reply to: Communication Line bound to server signal limitation #8874
    Thank you for the info.
    the signals sent to server seems to be uncertain when the limit is exceeded.
    It’s because of integer overflow. 5001 signals would send 319 items.
    in reply to: Views #8866
    Hi Matt,
    Thanks for the images. Interesting case.
    Probably, it’s needed to add a home folder with ID = 1. And the Overview scheme is inside the home folder with ID = 2.
    We should implement a possibility to move a tree node as you shown in the future.
    in reply to: MQTT #8865
    if we can solve problem with formulas and events there is plan to test on some real project where SCADA would be accessible from outside our LAN and we would monitor location in some other company
    Nice. I’m sure that all the mentioned issues can be solved. And I’ll help.
    in reply to: MQTT #8864
    About performance:
    Please wait a bit when we upload the driver update. The update will provide more details about received topics in the log.
    Then we should compare the driver with another MQTT client that is installed on the same machine as Communicator and subscribes the same set of topics.
    in reply to: MQTT #8863
    About the formulas:
    You should change channel type to “Real”. In this case, formulas are calculated when new value is coming from a controller or MQTT broker.
    in reply to: Views #8860
    Could you provide links to the screenshots? Screenshots are more clear than text descriptions, so we could find the solution faster.
    in reply to: MODBUS TCP CONNECTION #8859
    OK 🙂
    in reply to: MQTT #8858
    Note: the MQTT driver update is coming soon. The driver will support generating of input channels according to the configuration, and JSON parsing will be improved.
    in reply to: MQTT #8857
    As you can see on my images I have two formulas
    I don’t see any images that contains formulas. If you add them, I will check.
    Value is all the time the same as in communicator
    As wrote above, the result of formulas can be displayed by views, not in Communicator.
    I also noticed that Rapid SCADA takes quite some time to read data from Mqtt broker. When around 80 variables is published to Rapid SCADA it takes more then 1 minute to show all the data.
    Could you provide more info about that?
    If we choose Rapid SCADA for our projects can we count on official support or is Mqtt community developed and so unofficial?
    We also support the existing MQTT driver.
    in reply to: Views #8851
    I recommend to update the file structure on disk as you need to show in the tree
    Root
      SiteA
        NewFile.sch
    In the title column just enter simple titles.
    You can also set Title = Root\SiteA\Option1 but it’s not clear when not reflects file structure.
    in reply to: MQTT #8850
    Is it possible to use formulas for input channels that are using MQTT?
    Formulas are processed on the Server application level and they do not depend on a driver.
    The result of formulas can be displayed by views, not in Communicator.
