GSM Modul connection
Forum Home › Forums › Communicating with Devices › GSM Modul connection
  • #8219
    weissclemens1990
    Hello, i have a Problem With my GSM Modul. When the GSM Modul lost the Power supply the Modul doesnt remeber the pdu Mode. Can i send every Minute a command from Rapid Scada to GSM Modul to set the pdu Mode (at+cmgf=0)nice Regards from Austria
    #8221
    Try the following:
    1. Download KpTest.dll
    2. Add a new device with KpTest.dll driver to the same communication line as the modem.
    3. Manually send a binary command number 1 with the command value “at+cmgf=0”
    If it works, you send commands automatically with Automatic Control Module.
    #8222
    Likely it’s needed to update KpTest.dll because it sends some example data to the COM port.
