If you use OneDrive and you can’t load the Scada page
Forum Home › Forums › Installation Issues › SCADA-Web Installation › If you use OneDrive and you can’t load the Scada page
  • #8213
    hanjun941
    So I couldn’t get my installation working, I followed the installation instructions exactly but the Scada page wouldn’t load. I found out it was OneDrive windows update and it’s stupid name change path, to fix this go to Task Manager> Processes and End all tasks with the name ScadaAgentService, ScadaCommService, ScadaServerService, then run Cmd as Administrator and type in:
    SC STOP ScadaAgentService
    SC DELETE ScadaAgentService
    repeat for the other 2 services
    then delete your SCADA directory folder
    Go into Control Panel> System and Security>Administrative Tools> IIS Manager, Under Default Web Site directory Remove Scada.
    And just re-install from Scada installer and make sure the path is not on anywhere that is backed up by OneDrive, OneDrive changes the pathnames and makes IIS can’t find the files you need, I installed in C: and everything works fine now.
    thanks
    • This topic was modified 5 years, 8 months ago by hanjun941.
    #8220
    May be this is issue depends on particular OneDrive settings. I also use OneDrive and haven’t faced this effect.
    Thanks.
