Good temporary solution.
MikhailModeratorSorry, I checked the manual https://rapidscada.net/docs/en/5.8/modules/plg-dashboard and found that you can specify chart configuration file for v5 also. Please choose a method that is more comfortable for you: specify axes in the single file or create many files. Or combine the both methods.
This reply was modified 3 years, 9 months ago by
Thank you for the photo.Chart Pro for version 5 has a single configuration file. To set different colors for different quantities, you can define new YAxis with the specified Quantity ID in PlgChartPro.xml.
Chart Pro for Rapid SCADA 6 may have multiple configuration files. You can use the above method, or create different configuration files and specify them for dashboard. But, for now Dashboard Plugin for version 6 does not exist. So I wrote the 2nd method for the future use.
I’ve added the dependency upgrade to the task list.
There is no particular size option because this is how Bootstrap popups work.
Do you use Rapid SCADA 5 or 6? What screen resolution?
Make sure that the Agent service is running without errors by checking its logs.
If you need some help with that, provide screenshots and logs.
Could you provide a link to a screenshot of your existing dashboard? It would help to understand the issue.
That’s true, Rapid SCADA 6 is significantly different than version 5. It’s more simple and handy. Documentation will be added on https://rapidscada.net/docs/
Currently, there are instructions how to install the new version. Configuration manuals will be created after porting the existing modules, drivers and plugins.
MikhailModeratorUse EncryptPassword from this folder.
In the next version of the Administrator app, there will be a UI feature for encrypting passwords.
The keys can be updated for free for the same computer.
MikhailModeratorYou should reopen the project to read the changes in the tables.
Thank you for the update.
May be it would be more comfortable if you create separate devices (like CONTROL_2 etc.) on the same communication line. I mean if they related to different physical devices.
MikhailModeratorHello Tony,
There are no special recommendations.
Please use Microsoft docs for installing IIS on Windows server. -
