MikhailModerator🙂
MikhailModeratorRapid SCADA 6.1.4 has been released:
– Added the Code column in the Channels table. It can be used for integration with external software.
– OPC Classic driver supports sync mode for OPC DA.
– Other fixes and improvements.
It’s weird.
Anyway, today we published PlgChartPro 6.0.2.1. Please use the latest version.
MikhailModeratorI met this bug earlier with old OPC DA servers. I think, it is related with OPC client libraries, and we have nothing to fix in the driver. You can add OPC tags manually in the device configuration XML file.
MikhailModeratorNote: you have to change ScadaWebConfig.xml, set AllowAuthApi to true.
Connection is OK, but login failed. So check the log files ScadaWeb.log and ScadaServer.log
MikhailModeratorPlease download and install Chart Pro again. We’ve fixed this small bug without changing the version number.
Note: chart legend can be moved to the right if needed.September 21, 2023 at 10:04 am in reply to: rapidscada v6.1 opcDA SourceCode (DrvOpcClassic.Logic) #13428
MikhailModeratorOPC Classic Driver source code
This code is not on GitHub, because it refers the proprietary OPC dlls.
This reply was modified 8 months, 3 weeks ago by
Check TCP port that is used by the web application.
MikhailModerator1. Create similar file structure under the Views node.
2. Specify views in the Views table.
Is there a way to make it into minute?
This is possible in version 6.
Interesting idea. I suggest to try creating a module for the Server app, because it’s more flexible than formulas.
MikhailModeratorInstead of that formula, use
Cnl; 15which fits for channel of the Input/output type. -
