Server Slient Crash – ScadaServer killed by OOM killer on Linux
Forum Home › Forums › Runtime Bugs › Server Bugs › Server Slient Crash – ScadaServer killed by OOM killer on Linux
  • #12680
    JW
    Meanwhile, the ScadaComm service is still running.
    The service is started on 17Apr and killed on 11May
    https://1drv.ms/i/s!Akf5dL_rRmTTjjIapTXo9QQovpqB?e=ew5Ogi
    Manual restart on 23May. No detail of the crash in scadaserver log file
    https://1drv.ms/i/s!Akf5dL_rRmTTjjGBBE6c0YA5LPKa?e=Bjzdur
    Memory usage seems normal after restarting the service in servral hours
    https://1drv.ms/i/s!Akf5dL_rRmTTjjOoYEuXvna9pwDg?e=iHCjYr
    Have anyone encounter this issue before?
    This issue has appeared twice on the same server. Similar projects are running on similar servers, only this one have this issue.
    #12681
    JW
    As temporary measure, is there any recommended way to monitor and auto restart the service on crash?
    For systemd daemon file, it’s easy to add
    [Service]
    Restart=always
    RestartSec=30
    But the Scada 5.8.4 is using init.d, and the daemon file is a complicated script. Is there any similar to do it?
    #12686
    Some thoughts:
    – Server v5 requires a lot of RAM when trends (charts) are requested by a user.
    – Is it possible to check what amount of RAM was consumed by the Server service when it was killed?
    – 218 MB of free memory is not big. If possible, add memory to the server.
    – Rapid SCADA 6 uses systemd daemons. Consider moving to v6 in the future.
