Problem in exporting PLC run time
Forum Home › Forums › Understanding the Software › Problem in exporting PLC run time
  • #12687
    TDE
    I have tried to export the PLC runtime data, and it displays correctly in the web station. However, when I attempt to check if it has been exported to mySQL DB, I cannot find anything. Strangely, when I try to send the command value of the PLC runtime, it does show up in the MySQL DB. I believe the issue might be related to creating a command holding register for the input holding register of the PLC runtime, but nothing seems to work. Please help me.
    Thank you for your assistance with the correct English phrasing.
    https://drive.google.com/file/d/1d2YVi99k_jCBPPK5BO4Dl9jLqfVRZXTG/view?usp=drive_link
    #12688
    You should check the configuration and log files of DB Export module.
    Current data and events are exported independently.
