chika
ParticipantHello Mr. Mikhail,
I had a scada communicator error problem, then I tried to run the “Hello world” project but it also didn’t work.
https://drive.google.com/file/d/1H6bTrWVkFmA3d-uNh4iDgRU0sGN7KtOl/view?usp=drive_link
help me please.
thank youDecember 1, 2023 at 3:25 am in reply to: Issues and Error Handling When Starting a SCADA Project #13758chika
help me please.
thank youchika
ParticipantBelow I sent the file to C:\SCADA\BaseDAT\user.dat
https://drive.google.com/drive/folders/17M5qTnEi78XVX8yGbvFlybT94GqAK0XHThank you
chika
Previously, the Rapid Scada that I had was running normally, but currently the Rapid Scada can’t upload. How to fix it? (Error uploading configuration : Unable to login :- Invalid username or password)
In user-> Role application :
ID 4
Name ScadaAdmin
Password 12345ScalaAgent.Log is :
Agent
Started : 28/11/2023 16:26:54
Execution time : 1.00:15:34
State : normal
Version : 5.0.2.0Active Sessions
[-8879585298162833096] ::1; 16:42:09
[-7801325152737781735] ::1; 16:42:19
[-8318473730623925550] ::1; 16:42:142023-11-29 16:42:09 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -8879585298162833096 created
2023-11-29 16:42:09 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
2023-11-29 16:42:14 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -8318473730623925550 created
2023-11-29 16:42:14 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or password
2023-11-29 16:42:19 <DESKTOP-RKOT85G><SYSTEM><ACT> Session with ID -7801325152737781735 created
2023-11-29 16:42:19 <DESKTOP-RKOT85G><SYSTEM><ERR> User ScadaAdmin failed validation to connect to Default – Invalid username or passwordThank you
chika
ParticipantOn the Grafana dashboard, the data is displayed. but on fast scada the grafana dashboard is not there https://drive.google.com/file/d/1bbsQ2ZDodRatEUN_1QY1Ztkn_O2V8-NL/view
This reply was modified 2 years, 10 months ago by
chika.
chika
Participanthello I have tried to follow the youtube tutorial, but the runtime page displays “localhost refused to connect.” (https://drive.google.com/file/d/12FC7OO7hiFGqtKtUP9RXug-e_TYuucd3/view?usp=sharing)
chika
ParticipantFor example, I create 2 pages on the scheme (page1.sch & page2.sch)
then on page 1 I created a button which when pressed will move the display to page2.schand i have any question,can the scheme create a pie chart?
Thank youchika
can i make a button to move the page in scheme view? how to make it?
ThanksNovember 17, 2023 at 4:18 am in reply to: Unable to communicate with Device 1 because connection is not established #13650chika
ParticipantHello Mr. Mikhail, i have a problem in my line log :
2023-11-17 11:09:28 Communication session with the Device 1 “MyDeviceESP32”, type: KpModbus, address: 1, call number: 192.168.172.81
Request element group “MyGroupESP32”
Send (12): 00 E5 00 00 00 06 01 03 9C 3F 00 0A
Receive (7/7): 05 A1 00 00 00 06 FF
Incorrect MBAP Header data!How to fix it? Thank you
October 26, 2023 at 3:55 am in reply to: Using Formulas to count values and send them to MODBUS #13557chika
ParticipantI have displayed the push button (on-off) data with modbusRTU protocol in the table, and it has successfully appeared in scada. then I want to make a calculation of how many minutes the push button is on and off. can that be done? if possible how? Thank You
chika
ParticipantHello Mr. Mikhail, How to change the sampling time chart to every 10 minutes using a free chart?
Thank youchika
ParticipantI HAVE SUCCESSFUL, THANK YOU FOR YOUR HELP
chika
ParticipantSorry, there is a miss understanding about my last question. Here is what i actually mean :
I mean, if i have data 273 from modbusRTU but i want to display it as 27.3 on scada tables view. I have tried but, the data show is 273.00. Can you help me to solve this?
Thanks you mr. Mikhailchika
ParticipantHello Can I use free charts? or have to keep buying chart pro? thanks
