July 4, 2024 at 7:16 pm in reply to: Elastic report different default DateTime format for Excel #14889
JurasskParkParticipant@kcks66
Display of the time format (if the OS is Windows) depends on the setting Control Panel – Regional Options – Advanced Options – Date tab – Date format – full date format.
What can you choose there?
JurasskParkParticipantThe Administrator version of the application is written using WinForm, which Microsoft has not implemented for Linux. Therefore, there is no such folder for Linux, because administration works only in Windows.
JurasskParkParticipantIt is recommended to add screenshots to the service https://imgbb.com / If it is convenient for you to use the service onedrive.com to add screenshots, this does not mean that it is convenient for support to view screenshots through this service.
JurasskParkParticipantIf you have good knowledge of SQL writing queries, you can make a temporary table where you will add the current values. the trigger in this temporary table will sort the values into the required tables.
I wrote my own module and SQL scripts for this.
JurasskParkParticipantOn server or client side ?
On the server side.
You must create a Windows account there, which will be identical in login and password. And give her rights to the computer, DCOM and OPC server.
JurasskParkParticipanthttps://rapidscada.net/docs/en/latest/installation/install-windows
Is AspNetCoreModuleV2 installed?
JurasskParkParticipantWAGO PFC200 PLC key specifications & features:
SoC – Arm Cortex A8 processor @ 600 MHz (CNXSoft: possibly Texas Instruments Sitara AM335x processor)
System Memory – 256 MB RAM
Storage – 256MB flash, SD card slot up to 32GB
Fieldbus ports – 2x Ethernet; MODBUS, TCP/UD/RTU, CAN port, PROFIBUS Slave, Smart Grid and Serial RS-232/RS-485
Support for over 400 digital, analog, and specialty I/O modules
Temperature Range – 0 to 50°C or -20 to 60°C depending on modelMikhail:
Good afternoon!
Check the amount of RAM. If 1GB, it will work fine with ARMv7. If it is 512MB, there is a chance that it will work. If there is less memory, then most likely there will not be enough. -
