Forum Home › Forums › Installation Issues › SCADA-Web Installation › Webserver issues on win 11
- This topic has 2 replies, 3 voices, and was last updated 2 years, 7 months ago by
March 23, 2024 at 7:49 pm #14261
SystemD
ParticipantHello.
I installed Rapidscada tonight on my windows 11, but when i run the Webserver it doesn`t loadhttp://localhost:8899 <– i change the default port to 8899.
if i type http://localhost i get Internet Information Services page .
when i run Sevices and look for “ASP.NET State Service” its running “starts automaticly”
Log
2024-03-23 20:12:33 [HENRIK][ACT] Server 6.2.0.0 started 2024-03-23 20:12:33 [HENRIK][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll 2024-03-23 20:12:33 [HENRIK][ACT] Start logic processing 2024-03-23 20:12:33 [HENRIK][ACT] The configuration database has been read successfully 2024-03-23 20:12:33 [HENRIK[INF] Number of active channels for archiving: 8 2024-03-23 20:12:33 [HENRIK[INF] Number of active channels for sending commands: 2 2024-03-23 20:12:34 [HENRIK[ACT] Compile the source code of scripts and formulas 2024-03-23 20:12:35 [HENRIK][ACT] Added the following dependencies: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\netstandard.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.ComponentModel.Primitives.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.Console.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.Diagnostics.Process.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.Linq.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.Private.CoreLib.dll C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.3\System.Runtime.dll C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll 2024-03-23 20:12:38 [HENRIK][ACT] The source code of scripts and formulas has been compiled successfully 2024-03-23 20:12:38 [HENRIK_][ACT] Module ModArcBasic 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll 2024-03-23 20:12:38 [HENRIK_][ACT] Module ModArcPostgreSql 6.1.2.1 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll 2024-03-23 20:12:38 [HENRIK_][ACT] Archive Cur initialized successfully 2024-03-23 20:12:38 [HENRIK_][ACT] Archive Min initialized successfully 2024-03-23 20:12:38 [HENRIK_][ACT] Archive Hour initialized successfully 2024-03-23 20:12:38 [HENRIK_][ACT] Archive Events initialized successfully 2024-03-23 20:12:38 [HENRIK_][ACT] Start listener on port 10000 2024-03-23 20:12:38 [HENRIK_][INF] Archive in DAT format: C:\Program Files\SCADA\Archive 2024-03-23 20:12:38 [HENRIK_][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy 2024-03-23 20:12:38 [HENRIK_][ACT] Delete outdated data from the Min archive older than 24/03/2023 2024-03-23 20:12:38 [HENRIK_][ACT] Delete outdated data from the Hour archive older than 24/03/2023 2024-03-23 20:12:38 [HENRIK_][ACT] Delete outdated data from the Events archive older than 24/03/2023 2024-03-23 20:12:41 [HENRIK_][ACT] Session with ID 8539323844391146185 created 2024-03-23 20:12:41 [HENRIK_][ACT] Client 127.0.0.1 connected 2024-03-23 20:12:41 [HENRIK_][ACT] User ScadaComm is successfully authenticated 2024-03-23 20:12:43 [HENRIK_][ACT] Client 127.0.0.1 disconnected 2024-03-23 20:12:44 [HENRIK_][ACT] Session with ID 5399130187331576325 created 2024-03-23 20:12:44 [HENRIK_][ACT] Client 127.0.0.1 connected 2024-03-23 20:12:44 [HENRIK_][ACT] User ScadaComm is successfully authenticatedim out of ideas.
This topic was modified 2 years, 7 months ago by
March 23, 2024 at 9:28 pm #14262
JurasskParkParticipanthttps://rapidscada.net/docs/en/latest/installation/install-windows
Is AspNetCoreModuleV2 installed?
March 25, 2024 at 11:01 am #14274
What error do you get when open http://localhost:your_port ?
Does the above help? -
