WAGO PFC200
  • #14143
    peter_f
    Hallo
    I use Rapid Scada to show values of a WAGO PLC using Modbus. The PLC200 Series works with Linux as Operating System. WAGO sys that it would be possible to run some Software on the controller beside the WAGO Runtime.
    Now I wonder, if its possible to run Rapid Scada on te same controller an catch the Modbus values. So it would not be neccessary to use an additional Server.
    Is there any experience?
    Best regards
    Peter
    #14145
    JurasskPark
    WAGO PFC200 PLC key specifications & features:
    SoC – Arm Cortex A8 processor @ 600 MHz (CNXSoft: possibly Texas Instruments Sitara AM335x processor)
    System Memory – 256 MB RAM
    Storage – 256MB flash, SD card slot up to 32GB
    Fieldbus ports – 2x Ethernet; MODBUS, TCP/UD/RTU, CAN port, PROFIBUS Slave, Smart Grid and Serial RS-232/RS-485
    Support for over 400 digital, analog, and specialty I/O modules
    Temperature Range – 0 to 50°C or -20 to 60°C depending on model
    Mikhail:
    Good afternoon!
    Check the amount of RAM. If 1GB, it will work fine with ARMv7. If it is 512MB, there is a chance that it will work. If there is less memory, then most likely there will not be enough.
    #14150
    You can also run Scada on 256 MB, removing the excess if possible. But first you need to check the installation of dotnetfx 6 or 8. If it gets up and starts, you can try.
    #14151
    The ARM Cortex-A8 is a 32-bit processor core licensed by ARM Holdings implementing the ARMv7-A architecture.
    It is quite possible. But the web is definitely not worth putting on it 🙂
    • This reply was modified 2 years, 7 months ago by manjey73.
    #14153
    You need .NET 8, not .NET 6.
