How to show current date and time on scheme or dashboard
Forum Home › Forums › Development and Integration › How to show current date and time on scheme or dashboard
  • #10863
    AFP
    I want to know , if possible, how to show date and time in text box on scheme or dashbord.
    I would like ot show it as time reference for end users. Normally this should be server or computer time.
    NB: I’m working on Version 6 Beta.
    Thank you for your help.
    #10864
    victorlam
    I also would like to know how can this be implemented? Time shown is very important.
    #10865
    DateTime.Now.ToOADate() or DateTime.UtcNow.ToOADate()
    Date, DateTime or Time channel format
    The channel formula is no different from version 5 in this case, supported as in .Net Framework and in NET6
    • This reply was modified 4 years, 1 month ago by manjey73.
    #10870
    AFP
    Thank you manjey73,
    It just works perfectly.
    #10874
    victorlam
    hello, I also tried to use the formula DateTime.Now.ToOADate() and put this formula at one of my input channel eg 101. After upload to configuration, I do not see the current time and displayed with blank value or — at the scheme diagram.
    Can you share how this can be implemented? Or I have something that is missing for the setup and implementation.
    Or you can share screenshot to help on here.
    Thanks a lot!
    #10879
    JW
    check the use formula box.
    set channel type to calculated real.
    set formate to date and time
    #10880
    AFP
    I my case I leaved data type field empty. Verify your data type.
