MikhailModeratorAvailable at https://rapidscada.net/store/Module/en/ExtTrendJP
MikhailModeratorCheck Communicator – Communication Lines – Your line – Line Stats – Line Log
December 27, 2023 at 11:46 am in reply to: Use logical judgment to calculate equipment working time #13873
Something like (not tested)public double CountTime() { return Val(101) > 0 ? Val() + 1 : Val(); }101 – channel that stores the machine state
Then use this formula in a channel of the Calculated type:EveryMin(() => CountTime())
MikhailModeratorAlso, try specifying a byte order. For 16-bit float it could be 2301.
Usually, you should remove 4x from register address. Address of register 40000 is 0.
Formulas work with current data. To solve this task, Elastic Report Plugin can help. It can calculate the difference. See the example here.December 22, 2023 at 10:45 am in reply to: Use logical judgment to calculate equipment working time #13865
The related answer is here
If the motor change its state not too often, you can check it every minute and add a channel value if it is on.December 22, 2023 at 10:43 am in reply to: Create a channel with increment per minute using the value of a variable as step #13864
MikhailModeratorIn Rapid SCADA the general syntax of the formula would be
EveryMin(() => MyFunc())December 22, 2023 at 10:41 am in reply to: Can I update sch file without using the ScadaAdmin editor? #13863
On Linux the service is named scadaweb6December 21, 2023 at 11:39 am in reply to: Can I update sch file without using the ScadaAdmin editor? #13858
MikhailModeratorYes, you can update *.sch files in the destination location. To take them in use and clear cache, you need to restart the web application. You can do that using the Administrator app.
Also you can upload only views using the Administrator app.
MikhailModeratorCool! It can be useful for many users 🙂
MikhailModeratorRapid SCADA version 5 will be deprecated soon. Use Rapid SCADA 6.
MikhailModeratorScadaCommShell takes WinControl from this repository that should be downloaded either.
Yes, you can.
In the rolling mode, you can select only the length of the period in minutes. Max value is specified in the plugin configuration file PlgChartPro.xmlTo select a date, the fixed chart mode should be used.
