custom period of chart
Forum Home › Forums › Understanding the Software › custom period of chart
  • #13845
    grhsc
    I created the curve in the view this way
    cnlNums=3544,6464,4525,5161,2056,286&mode=rolling&periodMin=2880
    When I use the custom period in the upper left menu, the pop-up time selection can only select up to 1440. If I want to see the time period from yesterday or even earlier, can I select the date like in Chart Pro?
    https://drive.google.com/file/d/1t4OugDNYYa4BAn-UnTcMYBxTeKzVGuon/view?usp=drive_link
    #13849
    In the rolling mode, you can select only the length of the period in minutes. Max value is specified in the plugin configuration file PlgChartPro.xml
    To select a date, the fixed chart mode should be used.
