Viewing 15 posts - 631 through 645 (of 6,284 total)
  • in reply to: Events not changing #16140
    Please provide screenshots of the settings.
    in reply to: Is there a text field control? #16139
    You should add buttons on a scheme. When an operator clicks the button, a command dialog containing a text field is displayed. Set the Output channel property of the added buttons, and set proper button actions.
    in reply to: can not send command by web #16137
    Please provide screenshots of your settings.
    in reply to: No Table Editor #16136
    In v6, Table Editor is included in the Administrator app as a default extension. When you double-click a table view, it should be opened in the editor.
    in reply to: Out of Range Channel Data Mask #16125
    Conversion should be made using channel formulas as written above.
    in reply to: I would like to inquire about the visible/invisible function. #16120
    Connecting cameras also discussed here.
    in reply to: I would like to inquire about the visible/invisible function. #16119
    1. If you are asking about schemes, we plan to implement that feature in the future.
    2. To display a video stream you need to convert it to a web format. See this example.
    in reply to: Using AD for login #16112
    Have you created a PostgreSQL database and specified it in ScadaInstanceConfig.xml?
    in reply to: Using AD for login #16109
    Download is not needed in 99% of cases.
    When you upload a project, it is saved. You can also save the project by the Save button.
    If you gen an error, check the error details in the log files.
    in reply to: Change output state by formula #16108
    I thought all configurations should be done for channel which is referred in formula but configuration should be done on channel which execute formula, I’m right?
    Both is possible. A channel should not call SetVal for itself. When you need to change a channel itself, return a new value from the formula.
    in reply to: Using AD for login #16104
    1. In the Server – Modules page, activate the ModActiveDirectory module.
    2. Configure the module properties.
    LdapTest utility may help to find proper parameters.
    in reply to: How to use the chart #16103
    How to use the chart in the Extra Scheme Components Plugin,
    Specify the component properties to display a chart on a scheme.
    and how to change the default range of the scale from 0 to 100 to another range?
    Scale can be changed only manually by a user.
    in reply to: Change output state by formula #16099
    Val(52) is a wrong formula because it refers the channel itself.
    in reply to: Change output state by formula #16098
    V0.2 is the tag code of the channel. When a user sends a command to this channel 52, the command value should be transferred to Communicator. You can see it in ScadaComm.log.
    in reply to: OPCUA DA Gateway #16094
    Cool!
