MikhailModeratorThis is generic. This approach may be included in Rapid SCADA for different tasks
MikhailModeratorI can help you with Rapid SCADA. I am not a master of Arduino. I heard there are existing implementations of Modbus for Arduino.
MikhailModeratorAdd new device of Telegram type like written in the manual. Then open device properties in Communicator
MikhailModeratorYou can’t send function codes manually. You should configure Modbus template that uses the function codes you need.
MikhailModeratorFunction codes are predefined by Modbus standard. Why do you need your own function code? What is the register map of your device?
MikhailModeratorModbus template editor http://doc.rapidscada.net/content/en/use-cases/modbus-protocol-files/modbus_template_en.png allows to change “Data table”. The function code depends on the selected item: Holding Registers, Coils, etc. You can see function code below the Data table combo box.
Never use KP number 0. Make it greater that 0. Press a button (seems like a circle) to setup timeouts of the device.
Also you have to switch S2000-M to the printer mode and setup sending events using the standard Bolid utility.
To get answers in Russian, use http://forum.rapidscada.ru/
Could you describe an example? Do you mean something like SNMP traps?
MikhailModeratorI can give advice in general or about available functions.
Provide screenshots, please.
The refresh time is the same for all the parameters. All the data are received by a single web request. Otherwise, would be not optimal. Use the smallest value of refreshing.
You should develop your own formulas that calculates average values and reset them when needed. You should enter the formulas into the Formulas table in Administrator and use them from input channels. Also you can purchase creating such formulas.
MikhailModeratorDefinitely, very useful advice. Thanks!
MikhailModeratorIf you decide to start a new development using Rapid SCADA as a platform, I think, we should discuss it, may be I can do advice based on the user feedback.
Thank you! I hope, I will do such section in the future. Currently let’s communicate here. Please create new topics if they are not related to the subject of the current topic. -
