Viewing 15 posts - 4,921 through 4,935 (of 6,289 total)
  • in reply to: OPC Server Connection – E_NETWORK_ERROR #3458
    Try this utility to test https://yadi.sk/d/d1UOUw153DcoDp Does it work?
    When does E_NETWORK_ERROR occur?
    The OPC server also can be the cause of the problem. For example, we contacted with a developer on a one OPC server to append the proper implementation of all needed OPC methods. When he does it, connection was OK.
    in reply to: Some problems #3455
    I think, it is possible to create a component for schemes that can show IPcam in a popup window over a scheme.
    in reply to: ModDBExport #3454
    Why you don’t use hardware modules that counts off/on cycles? This would be much reliable and transparent.
    in reply to: ModDBExport #3453
    procSrez = curSrez;
    Save the reference to a snapshot which is processed.
    // вычисление новых данных входного канала
    Calculate new data of the input channel
    in reply to: Source Code KpOpc.dll #3452
    It would be good if you post here a link to your repository.
    in reply to: No library found for component #3451
    We should activate it by default.
    in reply to: ModDBExport #3440
    Could you open the code you interested in by GitHub and copy link to a particular line of code? Of course, I will help to understand.
    What happens if PC is off? Do you loose some switching?
    in reply to: Some problems #3439
    Do you ask me about the web page path to specify in the command?
    in reply to: Source Code KpOpc.dll #3438
    Do you have a project on GitHub?
    in reply to: No library found for component #3437
    Please check the log of the web application.
    Do you know where to find it?
    in reply to: Scheme Symbols/IMG #3436
    OK 🙂
    in reply to: Source Code KpOpc.dll #3428
    Good job!
    Creating new versions, I will try to simplify the object model and configuration.
    Have you tested the driver on Linux?
    What are the next steps in your development?
    Would you share the driver with the community?
    When it is ready, I can add a link to http://demo.rapidscada.net/plugins/Store/Store.aspx
    in reply to: Display text variable from OPC #3427
    Try ASCII text (8 chars) or Unicode text (4 chars) formats. Minimum version of KpOpc.dll is 5.0.1.0
    in reply to: Rspberry Pi installation #3423
    I usually use 8GB cards.
    May you need to clean the card and install all from the beginning?
    Rapid SCADA itself is very small. To realize how much space are needed for Mono and Apache, you should check the appropriate docs.
    Is it possible to get plain image file of the working RPI SCADA?
    I don’t plan to create such image because Mono and other packages are updated often by their teams.
    What image of Raspbian do you use?
    in reply to: Source Code KpOpc.dll #3422
    If it targets to .NET Core or .NET Standard, it should not use DCOM.
